building barns, sheds, houses - almost free
   / building barns, sheds, houses - almost free #1
North Texas
Kubota B7800
A lot of folks don't know this stuff exists yet so I figured I'd post a little bit and see if anyone was interested.
You can make blocks from shredded paper and portland cement that are both strong and have a high insulation factor - you can build just about anything out of them and you can get the paper free, in fact your doing us all a favor by keeping the stuff out of the landfills. If anybody is interested in how to do this let me know - it's easy and cheap - look up "papercrete" on a search engine and you'll find some good links.
You can mix huge loads of the stuff several ways using your PTO and a homemade mixer built out of a truck rear end, mower blade and a metal stock tank. It's easier to lay than brick or stone and a lot lighter weight but strong enough to withstand 150 MPH wind.
   / building barns, sheds, houses - almost free #3
Thanks Doug, I'll check it out.
   / building barns, sheds, houses - almost free #4
Hello Doug, good to see you here and also welcome. Sounds interesting, I need a good shop. When I get the time I will check out the links I just wnated to welcome you on here. We are good people to chat with.......teddy
   / building barns, sheds, houses - almost free #5
Welcome to TBN Doug. Thanks for the links. This sounds interesting. /forums/images/graemlins/cool.gif
here's some photos of stuff built (or being built) out of papercrete
   / building barns, sheds, houses - almost free #7
Might try building a new pump shed out of this Thanks for the heads up.
   / building barns, sheds, houses - almost free #9
Yes how does it hold up to rain ? From the pics those constructions seemed to be in an arid climate. Is it required to stucco over it ?
You have to waterproof it - elastomeric paint works well. Many people have built these in very rainy and humid climates and as long as they are waterproofed they work fine - if they are not waterproofed they will eventually start to deteriorate. I am planning to build my main house in a fairly rainy part of North Texas - I'm going to use papercrete for the walls and put a metal roof with a wraparound porch to reduce the problem to the point of insignifigance but I will still paint the house with a good latex to seal it. Domes are possible (even easy to build with papercrete) in wet climates but you REALLY need elastomeric roof coating after they are finished - papercrete will soak up and wick water if not coated. In arid climates with only ten instances per year of rain, coating is not all that important - papercrete has to get very wet many, many times before it will begin to break down.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Enmark Z Spray (A53316)
Enmark Z Spray...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
2019 Chevrolet Silverado High Country (A56436)
2019 Chevrolet...
19008 (A56859)
19008 (A56859)
