Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #21,221
A hint??? I do more than that just playing around! A 1.75 liter plastic fireball bottle has a nice report!! :D I was thinking probably 2 of those in that split would work.
"A hint" in my playbook could be more like a "claymore" . . . :eek: :ROFLMAO: .
/ Tractors and wood! Show your pics #21,223
Well, I milled the last of the cherry firewood logs today, and I decided to "live edge" this one, as I just couldn't bring myself to saw out the "sweep" in this log,
Man, there's nice wood right there!
SR
/ Tractors and wood! Show your pics #21,225
These pics were taken a few weeks ago, all the leaves have fallen now. I just love splitting wood in weather like this.
And it’s always cool when you find a little treasure in your wood.
The chickens seem to love it too
I typically stack my wood straight off the splitter, so I never have to handle the splits more than once before they go in the fire.
However this time I just liked it all. It’s amazing how fast the piles grow when your just splitting.
/ Tractors and wood! Show your pics #21,226
Just wondering why you seem to split into such small pieces ?
/ Tractors and wood! Show your pics #21,227
I do split my wood small. I have always preferred it this way, so in simple terms, it's just personal preference based on my own experience.
Originally though, I started splitting it small because I was never ahead and was always burning wood green, firewood will season/dry out considerably faster when split smaller, due to the greater surface area exposed.
In addition, my woodstove is on the small side as well, and I could fit a lot more wood in it with smaller splits (Woodstock Fireview), and lastly, my wife does and kids do a lot of the loading and also prefer it split smaller.
Now however, I rarely burn in the woodstove. I heat my house and hot water exclusively with an outdoor wood boiler. All my firewood is bucked to 23" length, and I still split it small for the same reasons, but on a bigger scale. The boiler seems to operate better because the wood dries out faster. Now, if I could ever get my act together, I would be burning seasoned wood and none of this would even matter lol.
The small splits that I prefer, are the main reason I like this specific wood splitter so much.
I fired up my wood boiler on October 15th this year, I'll keep it going until April/May depending on weather.
/ Tractors and wood! Show your pics #21,228
Nice series of pictures Piston. I like how you have a area to work up your wood right next to the boiler. I like the slug and chickens too - must have been some ants or beetles in there.
gg
/ Tractors and wood! Show your pics #21,230
Your tractor might do it with a long enough pull lead like a long cable.
Yeah, not with the location it is at, on the edge of a grown over road bed on the edge of a swamp.
/ Tractors and wood! Show your pics #21,231
If I were going to try that, I think I would first put some chain around it to prevent it from coming apart more.
Maybe a ratchet strap to draw it back together some.
Then, working alone, I would put some tension on it going the way I want it to go with my winch.
Start cutting below everything a little at a time (adjusting the winch as I go) until it breaks free.
Chain will slide up a tree a ratchet strap will blow a part with the force of a barber chair.
/ Tractors and wood! Show your pics #21,232
Yup... that could happen depending on where & how you chain it.
I was thinking of a heavier strap then you seem to be. They hold heavy equipment on semi's and I was just using it to close the split so it could be chained tighter.
Being aware of what COULD happen makes you think harder about what you actually do.
/ Tractors and wood! Show your pics #21,234
I understand that but, what’s the break out force of that strap? A barber chair will load that strap or chain instantly vs a load that’s constant. If something is very heavy at all such as with a lowboy application you will not see straps used it’s all chain and at least 1/2” or not 5/8” minimum even those don’t have the kind of strength needed to stop a barber chair.
/ Tractors and wood! Show your pics #21,235
Well you guys figure it out and come on over and show me how to do it.. I'll buy all the beer you can drink!
/ Tractors and wood! Show your pics #21,236
Hopefully you won't start serving until AFTER the tree is on the ground... or the evening before the tree is to come down. ;)🍻
/ Tractors and wood! Show your pics #21,237
Speaking of barber chairs. About 100ft tall. Mushrooms on the bark means it's dead and probably won't leaf out next year. Just wait for it to go over.
/ Tractors and wood! Show your pics #21,238
OK guys, this is what I started with,
And this is what I ended up with,
With the exception of two white pine logs on the load, the cherry tally is 324.3 bd ft...
All the pine that was with it in this second load,
has been milled and is gone too.
SR
/ Tractors and wood! Show your pics #21,239
In this case Hunt considering the surroundings, I'd leave it be.
None of us is gonna get there so you can have my beer.
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
(12) UNUSED FUTURE-FT LJ B12-8'X4' PROTECTION MATS (A60432)
(12) UNUSED...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
1043 (A60430)
1043 (A60430)
(4) 6 LUG FORD WHEELS W/CAPS & FIRESTONE (A60432)
(4) 6 LUG FORD...
2001 International 4000 DT 466E (A60462)
2001 International...
