Mahindra 4035 after bleeding the air out run but at 2000 and greater rpm’s sputters and blows out black then followed by blue smoke.
   / Mahindra 4035 after bleeding the air out run but at 2000 and greater rpm’s sputters and blows out black then followed by blue smoke. #11
I have no opinion on that, other than I wouldn't trust the sleeves. When you've exhausted all other avenues and still have air getting into the fuel (provided that is indeed the issue) then I guess I would cut those sleeves off as well and install clamps. See what difference that makes.
   / Mahindra 4035 after bleeding the air out run but at 2000 and greater rpm’s sputters and blows out black then followed by blue smoke. #13
Just another thought here. As I recall many of the "air in fuel" issues I ran into on the 4025 and 4035 were eventually eliminated by adding an electric supply pump between the tank and the filter base. At the time Mahindra warranty wouldn't recognize it because Mahindra technical hadn't approved it. I did it anyway and it seemed to solve the problem.
Thanks
Will this type of pump work?
   / Mahindra 4035 after bleeding the air out run but at 2000 and greater rpm’s sputters and blows out black then followed by blue smoke. #17
Have another question about the fuel tank removal on my 4035. The service manual it talks about removing the steering column. Any ideas?
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A51247)
2001 WELLS CARGO...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
