My Industrial Cabin Build
   / My Industrial Cabin Build #4,012
   / My Industrial Cabin Build #4,013
My shower pan build is going to be an absolute pain. My. Drain pipes are crooked. I did a crap job when I was putting in the rough plumbing and the drain pipes are coming up about 20 degrees off plumb. So I found a fitting that will allow me to straighten it. But by the time I get the fitting on with the shower drain above it, I am looking at a 7-8 inch step up for the pan( and a but more for the curb). I hate it. I cant chisel out the cement because i have two pex lines laid right up next to the pipe. that was a complete idiot move. And something an experienced builder would not have done.
Bathroom and shower remodels are my main source of income. Can you post a picture of your drain line? What size pipe did you use? What system are you going to use for your pan?
Whatever you do, do not create a step up to get into your shower.
There are so many different ways to build a shower pan that I find it hard to believe there isn't a solution out there.
   / My Industrial Cabin Build #4,014
You can repair the pex if you damage it. You need to get that drain straightened up at floor level, not above. Sucks.
You have more than one bath, right. So use the other one to begin with while you take your time to make this right. 100% agree with Eddie that an 8" step up into a shower is not good.
   / My Industrial Cabin Build #4,016
The only downside I have found about retirement is you no longer get vacation days, holidays or sick days. :D🤣
Lol, I still counted Monday as a holiday.
Originally plan was to use schluter system. With the membrane on the purple drywall and foam floor and curb. I will take a picture of the wonky 2 inch pvc pipe coming up. Slab is about 4 inches.
Both showers are like this.
Here is a quick video. I the. Used the level tool on my iPhone. It is 6 degrees off plumb
January 5, 2023
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
Kubota ZD326 60in Zero Turn Mower (A55851)
Kubota ZD326 60in...
Butterfly Artwork (A55758)
Butterfly Artwork...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
Misc. Tech/ Electronics (A53425)
Misc. Tech/...
