Cheap Wedling Helmet or Scam?
   / Cheap Wedling Helmet or Scam? #52
I use one of those cheap helmets.
I have my DIY test procedure that seems to work OK.
I call it "flick of my BIC" whereby my helmet should react instantly at the scratch of a flint.
   / Cheap Wedling Helmet or Scam? #56
having endured one arc flash (by my own stupidity), switching speed will always be the most important aspect of any hood and what I look at when looking at a hood. Usually, the faster the speed, the more they cost. Switching speed, then viewing area then hood coverage. A cheap hood won't have a fast speed.
   / Cheap Wedling Helmet or Scam? #57
My test for speed is as simple as a 'flick of my bick' i.e. the spark of a lighter flint, and I have done a fair bit of welding.
   / Cheap Wedling Helmet or Scam? #58
Works as well but if you buy a quality hood like a Jackson, the switching speed will be listed in the specs. You get what you pay for. Only takes one arc flash and you'll regret buying cheap for a long time.
   / Cheap Wedling Helmet or Scam? #59
...Only takes one arc flash and you'll regret buying cheap for a long time.
Do you know that every shield uses a Passive UV/IR filter; ensures no harmful lights can bypass. UV/IR never gets through any shield. The shading only blocks the bright lights.
Also, it's fine that you buy whatever you want...
   / Cheap Wedling Helmet or Scam? #60
I did not but I'll take your word on it. Sure about the cheap Chinses hoods too?
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
40' CONTAINER (A51244)
John Deere skidsteer (A55788)
John Deere...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
CATERPILLAR HYD HAMMER (A52707)
CATERPILLAR HYD...
