2520 Starts but wont run
   / 2520 Starts but wont run #11
Picture D
It is hard to tell where the wires are going to from your pictures and this is where a shop manual comes in handy. I can see that your solenoid is three prong which means there is a holding circuit after the start circuit. You should also be checking that the relay/time delay control module is working properly and sending signal when it should and that the hold circuit is energized as well. Perhaps someone here knows your particular machine better than I do and can chime in.
Another thing you may want to check is if the lift pump is actually creating pressure.
Here is a video that you may find useful to test the solenoid.
Hope this helps!!
Hope this helps!!
That's some good information thank you I'll check that in the morning.
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2007 Ford F-750 Chipper Truck (A52377)
2007 Ford F-750...
