2520 Starts but wont run
   / 2520 Starts but wont run #11
Picture D
It is hard to tell where the wires are going to from your pictures and this is where a shop manual comes in handy. I can see that your solenoid is three prong which means there is a holding circuit after the start circuit. You should also be checking that the relay/time delay control module is working properly and sending signal when it should and that the hold circuit is energized as well. Perhaps someone here knows your particular machine better than I do and can chime in.
Another thing you may want to check is if the lift pump is actually creating pressure.
Here is a video that you may find useful to test the solenoid.
Hope this helps!!
Hope this helps!!
That's some good information thank you I'll check that in the morning.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
