old and tired
- Joined
- Jan 15, 2019
- Messages
- 1,934
- Location
- Raleigh, NC/Hillsville, VA
- Tractor
- L2800 HST, 2005, R4 tires
Yes...I did not but I'll take your word on it. Sure about the cheap Chinses hoods too?
This is my first thought.What are your eyes worth?
having endured one arc flash (by my own stupidity), switching speed will always be the most important aspect of any hood and what I look at when looking at a hood. Usually, the faster the speed, the more they cost. Switching speed, then viewing area then hood coverage. A cheap hood won't have a fast speed.
Yeah, I'm one of the people that would get eye pain with any auto hood, even the $350 ones my job bought me. I'm happy with the flip helmets as my eyes don't hurt. Most people didn't have an issue though.It is stated by most manufacturers that UV and IR rays are blocked to the equivalent of shade 16 even if the lens is in the light state. That doesn't mean you won't get major eye fatigue from using too light of shade. As stated above. You only get one set of peepers so choose wisely.
You did good. Now 60 day delivery on your favorite.I have a pair of $50 Amazon welding masks and both are worlds better than my 20 year old $300 mask. I give my weld shop mask to visitors in my shop, I use the new cheap ones that fit tighter to the head, have 4 sensors, provide true color and far larger view areas. I honestly love them.
These are the 2 I have in my shop now. The red one is my go-to.
so like, don't eat flaming cheetos while watching XXX!My suggestion is to avoid using bi or trifocals or suffer the fate of old woodworkers who never cut a finger off until they got lenses that changed their depth perception by minor changes of their eye or head angle. You don't want hot junk touching yourself so if you need focusing lenses, use one consistent lens.
Thanks, just ordered it. My welding needs all the help it can get!!! Got some Cheater Lens, too...I have one of these: https://www.amazon.com/gp/product/B07ZWT6KBW/
It is a 1/1/1/2 and it was a game changer as far as seeing what I am welding.
For a sub $60 helmet, it's been the single biggest improvement in my welding.
Aaron Z
The GoGoNova works just fine, but why it is not my favored of the pair is the larger knobs located on the outside are a potential issue for me mig welding in tight spaces under vehicles where I could hit and move the adjusters. The other one has the more typical small knobs located inside where they can not be inadvertently changed while rubbing the mask around under the frame or in tight spaces.
I have a 15 year old (or so) professional auto dark welding helmet, I decided to order 3 new lesser expensive ones from Amazon to test out.
All 3 have provided a far better experience than my old $350 unit! What I can not speak to (obviously) is long term durability of the auto darkening functions and dirt/grit resistance of the controls.
This one, I'll call it the second of the 3 I just had shipped in, has the super large viewing window. Wow. I've never used a mask with the large full viewing area. I really like it! It helps greatly when your wrapped up tight under a vehicle and can not get your head and helmet fully aligned with the work location, with this you can actually look up/down from center with your eyes even though the helmet is hitting against something and can not be aligned correctly. This makes your welding job so much easier! It's the big screen TV equivalent of a welding helmet.
The first thing you'll notice if you are like me and coming from the older style is that these are "true color". That does take a bit to wrap your mind around, I am used to the greenish sort of night vision look of my old mask. These do not at all look like what I was used to. These provide a view that is 100 times better, both prior to the arc and during the arc.
If I were to call out a negative point on this (2 of the 3 welding masks I ordered have this same feature), and trust me it is subjective.... I am not a fan of the adjustments on the outside. I'll explain. They are more exposed to dirt and grit, they can be stuck on objects and damaged or could be rubbed and moved into an unsafe condition (related to eye protection). I would prefer the style with controls on the inside to mitigate these issues from a personal point of view. I say it is subjective because maybe others prefer the outside position like this so that the adjustment can be done without removing the mask, maybe the job is in a standing position working at a bench where rubbing and striking the controls is a non-issue. I work on vehicles and typically am shoving myself into awkward and cramp locations and bang the welding helmet a good bit.
The adjustability of this is all that you need. You can go as low as grinding mode or go into dark shade modes for welding with your preferred technique. And you will be shocked how much the image provided looks like you have on sun glasses! No more odd greenish hue. Honestly, I will never go back to my old welding mask. This is life changing!
Thanks.The GoGoNova works just fine, but why it is not my favored of the pair is the larger knobs located on the outside
I'm convinced, so I ordered it. Amazon says same day delivery! These must be popular around here.The GoGoNova works just fine, but why it is not my favored of the pair is the larger knobs located on the outside are a potential issue for me mig welding in tight spaces under vehicles
The GoGoNova GT001-L helmet arrived and I got a chance to try it today. I like it! It's a nice improvement over what I have been using. The larger window is nice, but not a critical feature. But the large 'natural-color' display is far better. I hadn't realized how much natural color improves your sense of what's out there. Also the unshaded view is much brighter, a lot easier to use with poor surrounding light. It's a keeper.The GoGoNova works just fine, but why it is not my favored of the pair is the larger knobs located on the outside are a potential issue for me mig welding in tight spaces under vehicles where I could hit and move the adjusters.
