I had a chance to putter with it this weekend. Weather’s getting tolerable
Thanks! That engine is the most difficult I’ve ever had to get parts for, you’re right about that. I spent probably 5 or 6 months locating that head, even talking to guys overseas. That one I got from Southern Global might be the last one in the worldTreat that K95 with love. There are really no more main replacement parts for it. It's difficult finding documentation on that engine too.
Glad you got things working better for the machine.
Good point about the temp! This machine doesn’t have a gauge, just an idiot light, which may or may not even be working at the right temp. Not too hard to actually install a gauge. Maybe that’s what I’ll do before I play with the timing anymore.That “clatter” is called diesel knock and is associated w either timing, poor spray pattern in the injectors or fuel quality..
Keep a GOOD EYE on the temperature.
Running “to much” advanced will raise to temperature QUICKLY..and warp the head..& u don’t want that..
About heat with these Japan tractors. Don't use 15W40 as the engine oil. The thicker oil traps and hold heat in longer. These tractors are made to JIS standards and not SAE. 10W40 or 10W30 are better picks for summer oil use and 5W30 for winter use.Good point about the temp! This machine doesn’t have a gauge, just an idiot light, which may or may not even be working at the right temp. Not too hard to actually install a gauge. Maybe that’s what I’ll do before I play with the timing anymore.
