Pat’s Quick Hitch / flail mower
   / Pat’s Quick Hitch / flail mower #21
TBN people giving their opinion on something when they don't even know what it is is just a waste of everybody's time.
I assume that was directed at me? If so, I can say with 100% certainty that I know as much about Pat's and JD QH as pretty much anyone. I think good discussions on a topic is never a waste of time. Someone will learn something when they read it. So if it was about me, tell me what I don't know.
   / Pat’s Quick Hitch / flail mower #22
My betsco flail is between cat 1 and cat 2 so a qh doesn't work. I have a qh on one tractor and I tried the pats on the other, it requires a longer top link as stated. I decided if I need to get off the tractor to connect the top link, I might as well do the others as well. Some implements are not qh compatible.
   / Pat’s Quick Hitch / flail mower #23
Right. I installed a QH only to discover it fit 50% of my attachments. Sold it and installed a QA which fits everything with a small easy extra step, which is to set the width or the drag links using the supplied spacer bar.
2017 Freightliner M2 106 24ft Box Truck (A56858)
2017 Freightliner...
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
2012 GALYEAN 160 BBL STEEL VACUUM TRAILER (A58214)
2012 GALYEAN 160...
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
