Major water leak Massey 165
   / Major water leak Massey 165 #11
Yes, but hard to picture how a blown head gasket puts a lot of water up under the rocker cover.
Cylinder heads have four sides. The top is covered by a valve cover. If the cylinder head cracked on the top the water will come out the head on the top. If the head is cracked on the top near a valve guide you will get water in the oil pan and in the valve cover.
   / Major water leak Massey 165 #12
Sight-unseen, all sorts of combos are possible. The pressure test should produce coolant flow out someplace and show where the problem is regardless.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2005 INTERNATIONAL 9400I (INOPERABLE) (A53843)
2005 INTERNATIONAL...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
