Limestone road base issue
   / Limestone road base issue #1
fishfrank
Member
I have a covered RV shed with both ends open to drive through. The floor is limestone road base. Can this be a cause of rust and corrosion? All the framing is rusted and everything parked in there develops rust in places. Anyone else have this problem? I cant find any good info on it and want to know before I get it all out of there. Shed is about 5 years old.
   / Limestone road base issue #2
Is the site well drained? Do you have a lot of humidity?
   / Limestone road base issue #3
Limestone does not cause rust. It's actually less acidic than dirt.
   / Limestone road base issue #4
Lime stone dust when mixed with water becomes quite alkaline which is corrosive.
   / Limestone road base issue #5
I would want to have a vapor barrier, too. This would help keep your limestone & dust from becoming damp, then sending corrosive vapors up through your equipment.
Might want to try a ridge vent to help vapors and if it were mine, I would run a couple low speed fans. Sounds like you are containing & confining the damp air, too.
   / Limestone road base issue #8
I would remove it and use crushed stone..
   / Limestone road base issue #9
When you check your equipment, wipe your hand on the steel frame, axles, etc.
If your palm feels damp or water droplets are present, there’s your proof.
2025 Wolverine CB-11-750F Jack Hammer for Skid Ste (A53117)
2025 Wolverine...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
