Limestone road base issue
   / Limestone road base issue #1
fishfrank
Member
I have a covered RV shed with both ends open to drive through. The floor is limestone road base. Can this be a cause of rust and corrosion? All the framing is rusted and everything parked in there develops rust in places. Anyone else have this problem? I cant find any good info on it and want to know before I get it all out of there. Shed is about 5 years old.
   / Limestone road base issue #2
Is the site well drained? Do you have a lot of humidity?
   / Limestone road base issue #3
Limestone does not cause rust. It's actually less acidic than dirt.
   / Limestone road base issue #4
Lime stone dust when mixed with water becomes quite alkaline which is corrosive.
   / Limestone road base issue #5
I would want to have a vapor barrier, too. This would help keep your limestone & dust from becoming damp, then sending corrosive vapors up through your equipment.
Might want to try a ridge vent to help vapors and if it were mine, I would run a couple low speed fans. Sounds like you are containing & confining the damp air, too.
   / Limestone road base issue #8
I would remove it and use crushed stone..
   / Limestone road base issue #9
When you check your equipment, wipe your hand on the steel frame, axles, etc.
If your palm feels damp or water droplets are present, there’s your proof.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
