MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 60,273
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Just got back from Oklahoma. I'd guess we saw at least 20 Tesla's on the road today alone.
How do we know if it's right? It's your story. I have been told that everything on the interweb is true though.Ooops I think I did the math WRONG
Surprised another sharp eyed Tesla owner did not catch my mistake
The car actually did better than I gave it Credit for.
IT used 60% of the available charge
car was charged to 96%
The usable battery in a model Y LR or Performance is ~76 KWH
The total battery storage is rumored to be 82 KWH
It used ~46 KWH not 60 KWH...
~ 46 KWH X .116 = $5.34
$5.34 to go 190 miles
regular 87 octane at the cheap station is $3.75
so the Tesla worked out to a gas car going the same distance having to get 133 miles per gallon at the local price for gas.
It actually beat the Monroney window sticker stating 106 MPGe hiway !?..??
edit
That can't be right can it??
Your good electric rates help. Nope, narrow front end. It was my dad's, when he died I wound up with it. We thought about getting one of those economical ev's but we just drive to work and back home these days with our hybrid suv that gets about 40 mpg. I do get the goldwing out occasionally for some touring at about 50 mpg.
Add $.01/mi if you do your own oil changes, or $.015/mile if you have them done at a garage. Either way, it doesn't bump the needle much. But since EV owners are always going on about the "maintenance" associated with ICE's, it helps to eliminate that argument.Refuel to full at the same pump the same way.
Look at the total dollar amount when the pumping stops.
There is the trips fuel cost.
Oh, maintenance is more than a oil change, owning a more premium ICE are not cheap, even the more ordinary car cost a lot in service cost, then you have cam belts, brake service etc.Add $.01/mi if you do your own oil changes, or $.015/mile if you have them done at a garage. Either way, it doesn't bump the needle much. But since EV owners are always going on about the "maintenance" associated with ICE's, it helps to eliminate that argument.
You started it 16 months ago. Turned a tractor forum into an EV circle jerk.Came to add something to the original today and it has been closed. Starting another. @Gale Hawkins
Found this today. Tesla has a prototype battery with 750 mile range. Now we are getting somewhere.
