Kubota L3540 Fluid change??
   / Kubota L3540 Fluid change?? #1
hunt4570
Super Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
Ok, I have a Kubota L3540 HST with loader. Changed the trans/hydraulic fluid and filters today. Followed my manual to the letter, drained the system, R&R both filters, the book says it takes 11.1 gallons of fluid, I put in 10 gallons and the dipstick says I'm quite a bit overfilled. Let it run for a while (per book) before operating the tractor, still over full, went for a ride, raising and lowering the bucket and such and still overfilled. Why, and should I drain some fluid out?
Thanks.
   / Kubota L3540 Fluid change?? #2
I never get 100% of the fluid drained. The OEM fluid capacity spec includes the fluid in the loader rams and hydraulic hoses, plus imagine getting all of the oil out of a very large irregularly shaped container.
Drain to the correct level and you're done!
Thanks, I was afraid you were going to say that.
   / Kubota L3540 Fluid change?? #4
Does your 40 series have a dipstick for the hydraulic fluid, or the sight glass? Reason I ask, is that the sight widows are notoriously difficult to accurately read.
On my previous L3410 I would take a final check of the sight glass level after the tractor sat unused on a level surface overnight.
   / Kubota L3540 Fluid change?? #5
Grand L 40's have a dipstick in the rear Diff housing. If you have a simple hand pump, stick a tube down in there and pump some out to avoid the nightmare mess of pulling one of the drain plugs just to take out a couple quarts. If you don't perhaps a trip to an auto parts or farm/equipment store is in order to get a simple/cheap hand plunger pump.
It, as stated above, has a dipstick. My last one a 3010 had the window.
I do have a suction pump I may try it, just afraid the volume is too much. I'll let you know, heading that way now.
So I tried my suction gun, about the size of a grease gun, it would have taken me all day, maybe all week, so I pulled one of the rear plugs, oily hands but a done deal!
So kinda on the same line, yesterday I was in TSC , was thinking about one of those pumps to transfer my fluid from the 5 gallon bucket instead of muscling it in there, read the instructions and it said each pump equaled 3 ounces.... so 10 pumps per quart and I needed to put in 10 gallons.. talk about a no go!
   / Kubota L3540 Fluid change?? #10
I have a small hand pump I used to fill mine on the 400 hr fluid change. It took a while as it does not pull much per stroke like you found, but the time actually goes pretty fast and I didn't have to balance those heavy 2.5gal containers over a funnel in the air...
Glad you got 'er dun
2013 Ford F450 Box Truck (A55272)
2013 Ford F450 Box...
TAKEUCHI TS50R SKID STEER (A52709)
TAKEUCHI TS50R...
2011 Nissan Rogue SUV (A56859)
2011 Nissan Rogue...
2016 CATERPILLAR 415F2 BACKHOE (A52709)
2016 CATERPILLAR...
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
