Kubota B7510 No Power
   / Kubota B7510 No Power #1
Ezzrider
Kubota B7510
I went out to start my B7510 and there was no power. Turned the switch on and heard a slight buzzing sound sort of what it makes when your battery has gone bad. After that nothing. No lights on the dash nothing. So I put on a battery charger and the same thing. The date on the battery was 7/2018 almost 5 years old hence I replaced the battery thinking the battery may have gone completely bad. Luckily Costco had the battery. Same thing. No lights on the dash nothing when I turn the switch. Lights, blinkers nothing works. I looked for loose wires, etc but found nothing. Any ideas of course now the grass has started growing on our 3 acres of land. I just used the tractor to cut grass 3 days ago with no issues. Thanks.
   / Kubota B7510 No Power #2
Try brightening the battery terminal connections as well as the the ground to frame lug.
   / Kubota B7510 No Power #3
If it’s not a loose battery cable described above, it might be a safety switch somewhere - make sure everything is in neutral, etc, etc.
On my zero turn, one of the wires for one of the safety switches somehow broke on its own a few years back. Had worked fine when I last used it, but nothing worked the next time I tried to use it. Luckily I was able to find it just looking around
Where is the ground to frame lug?
I have checked all the safety switches, and loose wires I could find. Possibly there is one hidden someplace.
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
Killbros 260 Seed Conveyor (A55301)
Killbros 260 Seed...
