Attaching Kubota mmm RCK54-23BX to BX2380
   / Attaching Kubota mmm RCK54-23BX to BX2380 #1
OroKubota
Oro-Medonte, ON
BX2380
I'm a pretty small and weak (especially after OHS) guy and I have a very difficult time attaching or removing the PTO shaft from my mower deck to the tractor. Anyone have any "tricks" that make it easier?
Thanks!
   / Attaching Kubota mmm RCK54-23BX to BX2380 #2
I just lay down on my back and slide head first under the rear end with the proper magnification glasses on. Sometimes I wear some old cotton gloves to get a better grip. I'm over 90 YO, 5'2" 140 lbs.
Cheers,
Mike
   / Attaching Kubota mmm RCK54-23BX to BX2380 #3
I’ve found that making sure there’s grease on both the pto shaft end and the coupler/receiver helps alot. Same with making sure the part of the pto shaft where the extension slides in and out is also greased. Even just WD40 helps.
Basically you just want every part to move around real easily.
Cheers,
Mike
Thanks for the suggestion Mike. I'm approximately the same weight and height, but a lot younger (77!). I've thought of doing what you suggest, but the BX2380 is smaller than the 2650, so very little room under the transmission.
   / Attaching Kubota mmm RCK54-23BX to BX2380 #6
Yep, I thought of that....after....I posted. It's been 13 years since I owned a BX model........
Now what? Darned if I know........except using plenty of lubricant and maybe some old gloves for grip.
Cheers,
Mike .............
   / Attaching Kubota mmm RCK54-23BX to BX2380 #7
My problem with hooking up the pto shaft is the slide collar. It is very stiff and hangs up. Don't really wnt to lube it because of the dust attraction. Any suggestions? Jon
2239 (A51244)
2239 (A51244)
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2022 LMC H40024 LOT NUMBER 206 (A53084)
2022 LMC H40024...
