Oil & Fuel 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime
Hi all...Conclusion time.
The Primary Pump mechanism was seized. Primary pump was replaced today and the tractor is running again!
Thankx to all that helped!
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime #32
Primary pump?? Do you have two pumps?
The unit attached to the Injection Pump that has the Primer attached. When I called Circle G to describe what I need he called it the Primary pump. So I have conveyed as informed. I will included pic for each and their own to apply the vernacular they are most familiar with if different.
   / 2003 Jinma 354 Starts runs 1 minute dies and will not restart without fuel prime #34
Oh, ok. That's called a lift pump. They are the source of fuel getting into the injection pump/governor oil sump when the O-ring seal fails. Many people, including myself, have replaced it with an electric fuel pump, which also eliminates the need for the priming pump. Approximately the same cost. Glad you're up and running!
2019 GALYEAN...
2006 Dodge Ram Power Wagon (A59814)
2006 Dodge Ram...
2007 Yamaha Rhino 660 (A56438)
2007 Yamaha Rhino...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
