JD 3pt Hitch Sway Chain adjustment Alternative
   / JD 3pt Hitch Sway Chain adjustment Alternative #1
gumshu
JD 2025R TLB, Kubota L4802 and Can Am Defender HD7
Has anyone replaced the stock LVA16683 sway adjustment chain with an after market brand? I find this stock adjustment chain on my 2025R difficult to secure with that silly ring. I’d much rather have a turnbuckle with locknut.
   / JD 3pt Hitch Sway Chain adjustment Alternative #2
Have a pic of the part with the silly ring? Wondering how it differs from a turnbuckle. tks
I don’t like these at all. That ring is a real pain
   / JD 3pt Hitch Sway Chain adjustment Alternative #4
In sailing, we call those "ring dings", and they're used by the hundreds on most boats. The good ones have one end turned in to a tighter radius than the rest, to make a real easy start. Nothing like a keyring, where you need to get a thumbnail between the leaves to start a key.
Maybe you just need better ring dings? Bonus, if you buy them from a sailing hardware store, they'll be 304 stainless.
My 3033R doesn't have chain, it uses sliding leaves with a pin dropped thru to lock their length. These do have the added advantage of keeping the arms from swinging out so far they can contact tire chains, if you're not running an iMatch or similar. So, if ditching your current rig altogether, I'd be searching for a similar non-chain type.
   / JD 3pt Hitch Sway Chain adjustment Alternative #5
Throw those ringdings as far away as possible and replace with a hairpin.
Thanks WinterDeere.
HalfTrack‘s Hairpin sounds like something to try… thanks.
   / JD 3pt Hitch Sway Chain adjustment Alternative #7
Perhaps you can find telescoping stabilizers that fit? If you can't, there is a fellow on Orange Tractor Talk that produces them to order. I could try to track down his information if you're interested.
   / JD 3pt Hitch Sway Chain adjustment Alternative #8
How will a hair pin prevent the turnbuckle from turning on the screw? The ring captures one leg of the turnbuckle, it's not just there as an end stop!
I used to use a few of those ring dings every weekend, on the forestay and the jib tack of one of my racing boats. They're really not a big deal, takes about 2 seconds for the type shown in my photo. The ones the OP showed are much more troublesome.
   / JD 3pt Hitch Sway Chain adjustment Alternative #9
This type of pin is what I was referring to. Hair pin, lynch pin, or genie pin. Unless those turnbuckles develop a lot of torque, they will limit turning to less than 180 degrees.
   / JD 3pt Hitch Sway Chain adjustment Alternative #10
Yeah, that's what I figured you meant, just my eye was telling me the length of a hairpin that fit that hole might not be enough to prevent rotation of the turnbuckle. But looking at it again, I was probably wrong on that. If that does indeed prevent the thing from spinning, it's definitely the easier solution.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20' 1 Trip Shipping Container (A59814)
20' 1 Trip...
Dodge Charger (A56859)
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
