Komatsu D20A Steering clutches stuck
   / Komatsu D20A Steering clutches stuck #1
Sidman
Komatsu D20 A
Does anyone know what the 2 solenoids on top of the steering pump do and how to check if they are the problem. I've tried everything else.
   / Komatsu D20A Steering clutches stuck #2
Best I recall there are no solenoids on the pump but slave cylinders on the steering actuators, I believe those are dry clutches and if it’s sat any length of time they are probably frozen/rusted from moisture.
Thanks for getting back to me. It sat for 7 years under roof. I was hoping not to tear into the clutches. I was getting oil to the slave cylinders.
   / Komatsu D20A Steering clutches stuck #4
If the actuators are working and you have room you could try running the machine back and forth or under load while steering one way or the other, may jar it loose depending on how bad it is, dry clutches can indeed be a pain, good luck with it.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
FAKE (A52472)
FAKE (A52472)
