Komatsu D20A Steering clutches stuck
   / Komatsu D20A Steering clutches stuck #1
Sidman
Komatsu D20 A
Does anyone know what the 2 solenoids on top of the steering pump do and how to check if they are the problem. I've tried everything else.
   / Komatsu D20A Steering clutches stuck #2
Best I recall there are no solenoids on the pump but slave cylinders on the steering actuators, I believe those are dry clutches and if it’s sat any length of time they are probably frozen/rusted from moisture.
Thanks for getting back to me. It sat for 7 years under roof. I was hoping not to tear into the clutches. I was getting oil to the slave cylinders.
   / Komatsu D20A Steering clutches stuck #4
If the actuators are working and you have room you could try running the machine back and forth or under load while steering one way or the other, may jar it loose depending on how bad it is, dry clutches can indeed be a pain, good luck with it.
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
