Change fuel shut off/kill switch cable on Ford 3600
   / Change fuel shut off/kill switch cable on Ford 3600 #1
MikeAC
Member
Pa
'72 Power King Kubota B2710 Ford 3600
I have to change the fuel shut off cable on a Ford 3600. Any suggestions on how to reach the lock nut on the underside of the instrument panel?
I can't figure out how to get a wrench on it even if I remove the cowling , and i'm thinking that trying to cutting it off with my fordom handpiece may be the best option
   / Change fuel shut off/kill switch cable on Ford 3600 #2
What I've done is to pull the wire out (unless it's rusted solid) the cut the cable shell as short as possible. Slip a box end wrench over the cable and onto the retaining nut. Grip, hold, and/or turn the flange on the outside with vise grips. Sometimes they can be difficult.
Using PB blaster i let the retainer nut soak for a month , i then cut the cable and managed to break the nut free and used a 3/4 “ socket on the underside of the panel , and holding that with my right hand i used a vise grip to unscrew the whole rig from the outside
   / Change fuel shut off/kill switch cable on Ford 3600 #4
Sounds familiar.
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
Peterbilt (A51692)
Peterbilt (A51692)
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Kubota ZG327 (A50120)
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
