Good morning!!!!
   / Good morning!!!! #173,041
Discovered a tree down in the tree plantings. Will see how close I can get with the tractor
   / Good morning!!!! #173,042
a/c won't get house below 78. runs constantly. I changed the filter, doubt that will help.
Will have to call guy who installed it two years ago if no improvement.
93 next two days
   / Good morning!!!! #173,043
93 next two days
What was your outside temp today?
   / Good morning!!!! #173,044
^^^^Dang that's not good^^^^
I did get the AC working in my Branson this afternoon, new condenser and dryer installed, vacuumed down, oil added, recharged and working pretty good. Temp out of the vents 45F with the ambient being 85F and sitting in the sun.
post #1366 in this thread
What have you done to your Branson today?
   / Good morning!!!! #173,045
93 next two days
Is the unit icing inside...copper line or condenser coil?
   / Good morning!!!! #173,046
The plumber was here this morning and fixed the water leak at the accumulator tank. Pretty neat how they used a battery operated compression tool to crimp the copper tubing.
View attachment 810586View attachment 810587
Using Propress is the cats meow,no soldiering or smell just have make sure no burrs on cut tubing,only down fall fitting prices. compare to solider fittings.
   / Good morning!!!! #173,047
Feel the larger line going into the condenser outside. It should feel like a beer you just took out of the fridge.
Is there condensate dripping from the evaporator drain in the basement?
   / Good morning!!!! #173,049
Good (Wednesday) morning. Overnight Low was a balmy 11.5C and it's presently 16.4C... well, 'they' did say that it would be a mild Winter. It's partly cloudy with a steady wind from the NW.
We (MAHW & I) did do the horse transfer from Paddock #1 to #2. Whilst waiting for her to arrive I took care of a few tasks in Paddock #6; disposed of a pademelon carcass (died of natural causes) and sprayed a particularly obnoxious weed (looks like a fuzzy cabbage). I then forked up 4xwheelbarrow's worth of rotting hay & disposed of that.
I'll soon chain-harrow Paddock #1, however I think that I'll also re-harrow #6 as it's still too damp to mulch with the Z-turn.
Anyway, it's 'into town' day for mail/groceries. I figure that I'll also stop by the hardware shop for about 8 links of 'gate' chain, some small shackles and a small pair of bolt cutters. I need to extend a couple of gate chains as, over the years, the wire tension has shifted the gate posts away from a couple of gates.
   / Good morning!!!! #173,050
72F clear sky.
Busy day which I didn't plan on,neighbor down the road ask if I could fix there wash out driveway so off I went Kubota back blade attach also shovel and rake,couple hours later and request from her neighbor if I could do the same so headed there afterwards,got home having lunch and first neighbor call wondering if I could do another driveway...so off I went but that driveway harder for it long and windy driveway longer to do,got some much needed seat $450 dollars for the 3 jobs customers happy...guess Iam pay for dinner on date this week.
Heading to set on the deck enjoy smooth cigar.
Enjoy your evening all.
TUGGER TRAILER (A58214)
TUGGER TRAILER...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
WEILER S350 SKIDDER (A60429)
WEILER S350...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
Cub Cadet Riding Lawn Mower (A59814)
Cub Cadet Riding...
2461 (A58376)
2461 (A58376)
