Kaufman 22' tilt deck equipment trailer purchase
   / Kaufman 22' tilt deck equipment trailer purchase #11
I've had great service with Kaufman trailers (2 of them).
   / Kaufman 22' tilt deck equipment trailer purchase #12
   / Kaufman 22' tilt deck equipment trailer purchase #13
I think a lot of trailer manufacturers have “shortcut” versions.
Just have to do your homework.
   / Kaufman 22' tilt deck equipment trailer purchase #14
So far my equipment trailer has been great. No problem with Kaufman.
Be advised, Kaufman uses some hybrid 8k axles with 3" tube and 2" brakes. You might want to confirm, if in doubt. Standard 8k is 3.5" tube and 3 3/8" brakes.
8k Electric Brake Axles - Kaufman Trailer Parts
12"x2" Electric Brake Assembly - Kaufman Trailer Parts
I have never heard of Hybrid axles but I don't see where it says the tubes are 3" rather than 3&1/2, but it does appear that those axles use 2" brakes, maybe this trailer is full of shortcuts, guess I won't know until I get it and put it to use, hopefully since the axles are rated for 8k they will stand up to the 11k that I am going to be hauling on the trailer, they told me that the payload on the trailer was 13,300 pounds.
   / Kaufman 22' tilt deck equipment trailer purchase #16
I bet you’ll be fine
   / Kaufman 22' tilt deck equipment trailer purchase #17
   / Kaufman 22' tilt deck equipment trailer purchase #18
Not saying Kaufman uses these but just an example, they are out there. With your use, it might not even mater to you. Getting the 17.5's is a big plus.
For my use, I want the big axles and brakes.
8k Sprung Lippert Hybrid Trailer Axle - 8000 lb Electric Brake 8 lug (12" x 2" Brake - 3" Tube) | Axles | The Trailer Parts Outlet
I would like for it to be as heavy duty as possible as it will mainly be hauling my skidsteer with forestry mower attached, so around 11k, I have been hauling it on a 20' equipment trailer with 2- 7k axles and it has worked but it is overloaded, roads around here are so bad with pot holes that I have put a slight bend in both of these axles on the passenger side of the trailer. I really wanted a gooseneck but I just can't get it in most of the places that I go, but the bumper pull will follow the truck so much better in tight driveways.
   / Kaufman 22' tilt deck equipment trailer purchase #20
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
Wolverine Quick Attach Skidsteer Grapple Bucket (A59814)
Wolverine Quick...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
