Ford 555 3cyl diesel acting up
   / Ford 555 3cyl diesel acting up #1
Palpater
Older Ford backhoe
It will start fine cold but after warming up it will not restart without a shot of either. Runs fine until I shut it off and then then it just turns over trying to restart.
Any help much appreciated.
   / Ford 555 3cyl diesel acting up #2
How many hrs on the machine?
A lot. It’s an 83 that has far outlived the hour meter.
   / Ford 555 3cyl diesel acting up #5
I found this on the internet >
Also the most common reason of the difficult diesel engine warm start - wear-out of the plunger and barrel of the fuel pump. If plunger and barrel are worn out - cold fuel can be transported; however, as soon as the fuel warms up - it becomes more watery and cannot be transported by plunger and barrel easily.
   / Ford 555 3cyl diesel acting up #6
Check the compression. It should be above 325-350 psig as a minimum.
   / Ford 555 3cyl diesel acting up #7
Other details to help online diagnostics is does it smoke and what color smoke? I suspect low compression too!
   / Ford 555 3cyl diesel acting up #8
Since starting fluid gets it going when warm that tells you timing and compression is good enough...but it also tells you fuel isnt there.
   / Ford 555 3cyl diesel acting up #9
The 555 runs a CAV/Delphi injection pump.. they’ll run + or - a bucket of dirt.. but once the head and rotor goes bad, it’s bad.
Next time u go to start it, loosen the bleeder screw by the name plate FIRST..(5/16)
Loosen the screw, crank the engine till it shoots fuel and NO AIR.. tighten the screw, pull the throttle to wide open and see if it’ll start..
I’m not sure weather or not that 555 has a “flame thrower” in the intake.??
If it does, it’ll be screwed into the aluminum intake manifold right where the rubber boot ends..
If it does have one, do a search for “thermo-start”
for operating instructions..
Good luck
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
378467 (A51572)
378467 (A51572)
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Mitm Corporation 4003 Pressure Washer (A53117)
Mitm Corporation...
Aluminum Boat Top (A53117)
Aluminum Boat Top...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
