Issue refilling a Lincoln grease gun
   / Issue refilling a Lincoln grease gun #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Ive got a great Lincoln grease gun, but .....
When replacing the tube refill, the piston seal will not pass the cardboard tube entrance. I've tried Manipulating the spring/rod over and over, but can not get the piston to make the jump. No piston pressure, no grease coming out the business end.
I end up pushing the grease out of the refill tube and into the gun tube with a turned up plug and a broom handle. Messy!
I don't have a tub pump, and don't really want one to refill by way of the fitting.
Is there a way around this?
   / Issue refilling a Lincoln grease gun #4
I've never had problems with any of my manual grease guns. But then - I bought a battery powered DeWalt grease gun. Could not get the plunger to go down the new tube and push the grease.
AH - HA ..... then I found the pressure relief fitting on the grease gun. Open this fitting - release the air pressure ahead of the grease - the plunger goes down the tube - all is well.
It was probably covered in the Owners Manual - but, who ever reads those things.
   / Issue refilling a Lincoln grease gun #5
Interesting. I have a Lincoln as well and have had the same issue a couple of times but usually I can get it to work. My problem is now the grease is bypassing the seal and getting behind the plunger so when I pull the plunger back grease shoots out of the shaft hole. Probably half the tube. I'm now using my Dad's last "old" grease gun. I have a Milwaukee I guess I'll have to break out.
I've got one gun that leaks past the plunger seal. I store that one with the spring guide retraction rod pulled out. 'saves a lot of grief/grease. ;-)
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
John Deere 272 Grooming Mower (A59814)
John Deere 272...
pressure washer, and trailer (A56859)
pressure washer...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
