2018 John Deere 5055E Ignition Switch Fuse blows
   / 2018 John Deere 5055E Ignition Switch Fuse blows #11
…Mine doesn't have the cold start advance sensor in the thermostat housing like the older models have.
Your 55 is a 3cyl. Completely different animal than the 4cyl with cold start sensor.
   / 2018 John Deere 5055E Ignition Switch Fuse blows #12
   / 2018 John Deere 5055E Ignition Switch Fuse blows #13
I am having the same problem with my 2021 JD 5065E. What ended up being the problem?
   / 2018 John Deere 5055E Ignition Switch Fuse blows #14
welcome to the forum isn't tractor still under warranty? Don't want to do anything to let JD out
   / 2018 John Deere 5055E Ignition Switch Fuse blows #15
Thanks for the help i have a 5055e same problem and it was that sensor unplug it and started right up
   / 2018 John Deere 5055E Ignition Switch Fuse blows #16
So exactly where is this sensor on the 3cyl engines ?
Jack Daniels Sign Decor (A51694)
Jack Daniels Sign...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
2025 CFG Industrial QH12R (A50123)
2025 CFG...
