2018 John Deere 5055E Ignition Switch Fuse blows
   / 2018 John Deere 5055E Ignition Switch Fuse blows #11
…Mine doesn't have the cold start advance sensor in the thermostat housing like the older models have.
Your 55 is a 3cyl. Completely different animal than the 4cyl with cold start sensor.
   / 2018 John Deere 5055E Ignition Switch Fuse blows #12
   / 2018 John Deere 5055E Ignition Switch Fuse blows #13
I am having the same problem with my 2021 JD 5065E. What ended up being the problem?
   / 2018 John Deere 5055E Ignition Switch Fuse blows #14
welcome to the forum isn't tractor still under warranty? Don't want to do anything to let JD out
   / 2018 John Deere 5055E Ignition Switch Fuse blows #15
Thanks for the help i have a 5055e same problem and it was that sensor unplug it and started right up
   / 2018 John Deere 5055E Ignition Switch Fuse blows #16
So exactly where is this sensor on the 3cyl engines ?
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2016 FONTAINE 53FT SPREAD AXLE DROP DECK FLATBED TRAILER (A53426)
2016 FONTAINE 53FT...
20" Sea Container (A47384)
20" Sea Container...
