NoTrespassing
Elite Member
123-75%=30.75
World markets determine prices, not just one country.
Goldman Sachs warns that Russia and Saudi cuts could send oil prices above $100 a barrel by the end of 2024, just in time for Election Day
Should oil producers choose next year not to reverse their cuts, then the Biden administration may have a problem on its hands.www.yahoo.com
Where did you learn math. But lets check your work. If you take 30.75 and add in 75% to it (add a 1 to the % and multiply), what do we get? 30.75*1.75 = 53.81.123-75%=30.75
Pretty sure I didn't say 1 country. I used the plural, iirc.World markets determine prices, not just one country.
Percent of a number, percent change from initial to new/current number, and percent difference are all different things.
If I had 10 apples and now I have 20, 100% increase.
If I had 20 apples and now I have 10, 50% decrease
V1 is initial number (in terms of time old)
V2 is the new/final number (in terms of time new)
percentage change = (Vfinal - Vinitial) / Vinitial × 100%
Just think about it logically and stop repeating what your website says. It obvious your confused.
The price dropped from 123 to 70. You can always check math, with math. So lets check it.
70 * 1.43 = 100.10
70* 1.75 = 122.5
Damn , this is not hard.
I taught math to undergrads while I was a grad student. There was always a kid on a hill that, even when presented with mathematical checks, would argue he was right. They never were.
We are here.
See, in post 40 I defined what I was calculating, which is the last cycle of peak to trough.Your chart.
12/2021 - $70
6/2022 - $123
3/2023 - $70
There was a 75% increase in value between 12/2021 & 6/2022
There was a 43% decrease in value between 6/2022 and 2/2023
If we are discussing percent change over time for a value. This is how it works.
If it was 50% decrease in value from 6/2022 to 3/2023 would have bee 61.50, 75% decrease in value 30.8, 100% decrease in value 0.
… the order of the values in the numerator doesn’t matter much, the correct denominator value is what is important, original/first value always goes in the denominator, provided you can figure out a negative number…
I don’t have any base math texts from grade school for a pure percent change formula that isn’t ‘from the web’, but here is a percent change snippet from Mechanics of Materials by RC Hibbeler from an entry level engineering class.
Not sure what you are trying to prove with this:
70 * 1.43 = 100.10
70* 1.75 = 122.5
70 with a 75% increase is indeed the same as 12/2021 to 6/2022.
(123-70)/70 * 100% = ~75%
Your proof however doesn’t reflect percent change.
see post 43.Here's the things most of us see....
$123 high
$70 low
That's a difference of $53
$53 is about 43% of $123
Most of us see a 50% price decline from $123 as leaving it at $61.50.
A 75% price decline from $123 would be leaving it at $30.75.
Without slinging insults, is there a different way of explaining it to come up with another answer?
I did. We all did. None of us understand what you're trying to convey there.see post 43.
Then you come along and have to redefine what I was calculating to make your point of: Trough to peak, to trough again.
You change the goal posts.
All that *100 at the end does is move a decimal point over by 2. However I express the solution in a %, which does the *100 automatically. I know that .75 expressed as a % is 75%. See post 40 again to see my solution is in a %.
Your not going to get me in a game of gotcha with math. I'm an Actuary, I do math all day every day for a living.
Haven't seen one person get the lightbulb turned on and say "Ah, now I get it."
Glad you figured out decimals to percentage as an Actuary.
“So if we take the peak of 123 and the low of 70, which was March of 22-March of 23 that is a 75% decline of price.”
The goal posts you set above.
Time and values.
$123 - March 22
$70 - March 23
I added the other through to peak for clarity of point on calculations.
I don't understand post 43, that's why I'm asking.Moss...you've always been a reflexive contrarian.
If you understood post 43...I mean really understood it. You would have your ah ha moment. But again, contrarian.
It dropped by 75%. I don't know how else I can make you understand that.
