Is a fully discharged battery now junk?
   / Is a fully discharged battery now junk? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I mistakenly fully discharged the battery in my MX 5100 Kubota. It was a replacement likely made by Interstate. The battery was so dead it even tripped the 50 amp main fuse and I didn't know it could do that.
Anyway, I've been slow charging that battery but I have the feeling it's no good after a full discharge like that. Anyone know about this?
   / Is a fully discharged battery now junk? #2
My understanding is it actually can be good for them to be discharged then charged fully back up. Try it and see.
   / Is a fully discharged battery now junk? #3
Ive fully discharged batteries-even 2 of them- in larger tractors and they always recharged for me.
   / Is a fully discharged battery now junk? #4
I've discharged a new battery, charged it back up and it came back full. Been lasting 5 years now
Wow, thank you all for the voice of optimism.I've bought a lot of batteries this year and don't need any more.
It must be an old wive's tale that fully discharged ruins a battery. Or maybe that was in the olden days. These days I charge batteries just before the cold starts and I've had great luck with longevity.
   / Is a fully discharged battery now junk? #7
Fully discharged from slow leak is ok 1ce or twice & maybe 3 times. High discharge can swell/ruin the plates, especially if water level is way down. Using distilled water is best but hardly anyone pays any attention. Mineral water == slow short circuit. Plus, high charge rate bubbling puts acid on the case top so another slow death/drain. Some batteries can last 20 years. some last 2 years depending on how careful and respectful you are with them. No battery: no tractor is how I respect them.
   / Is a fully discharged battery now junk? #8
Only one real way to find out, charge or jump it and see what happens.
I needed the tractor so put a spare in and the discharged battery is on a 3 amp slow charge "smart" modern charger. I never understood boiling the cr*p out of them with a high amp fast charger.
I'll let it slow charge longer and then see what happens. All good to know.
   / Is a fully discharged battery now junk? #10
Discharged batteries start to oxidize the lead plates. Leaving batteries discharged for extended periods is definitely bad.
Single time and it was charged fairly quickly….may not be a certain death sentence.
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 NISSAN Pathfinder (A56859)
2015 NISSAN...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
1111-A (A54756)
1111-A (A54756)
Bucket (A55973)
Bucket (A55973)
