Which paint for covering up smells
   / Which paint for covering up smells #11
A thorough cleaning can do wonders to get rid of odors. I own a commercial carpet cleaner. There can be a heck of a lot of odor trapped in a carpet.
   / Which paint for covering up smells #12
I would do a meticulous inspection to make sure that there wasn't something left behind that is giving off the odor.
Doug in SW IA
   / Which paint for covering up smells #13
Felt sorry for some folks that bought a local small house that they wanted to fix p and rent out. It had been used prior as a cook house for Meth. They are still working on it two years later. They've had to gut the entire interior down to studs AND replace the entire septic system and the entire septic leach field. I guess the Meth cooks just flushed all their old chemicals? I looked at it briefly when it was up for sale. It was cheap for the area, but then I saw the DEQ sticker and RAN.
I used B-I-N as a vapor barrier all though out my house while building. It off gasses a bit, as does KILZ, so your gonna want some strong ventilation fans going during application and forego the tradtional after work 6-pack. :)
   / Which paint for covering up smells #14
I had a situation on a concrete floor with a really bad residual smell left behind from decades old sour gear oil. I could not get the smell out and even tried acid washes and such. Sherwin Williams advised painting the floor with their two-part epoxy 9000 floor coating and I did that. Problem solved.
Which leads me to suggest getting in touch with a Sherwin Williams paint place, or something similar and asking questions. They have paint engineers you can call as well. They have been through this before.
As well, I know that epoxy worked on my floor so maybe there are paints that are epoxies suitable for other surfaces?
The walls may be a bigger challenge because it seems paper and plaster would be easy surfaces for smells to penetrate.
   / Which paint for covering up smells #15
Concrete is porous even though it doesn't look like it.
What floor and ceiling materials do you have? Drywall on the walls? Anything else left in the room that would have absorbed odors?
Floor and ceiling are drywall. The floor is either going to be replaced or covered. The existing floor is a floating floor but some of the floor is wet and damaged. I cannot find the source of the water. There is no plumbing to the building and the wet spot is a couple feet from the wall and the only door. I am going to remove the sections of flooring where it is wet. When our house was built we had 3/4" maple floors put down. Truly lovely and wonderful floors. And we had flooring left over. It has been stacked in the garage up off of the floor for about 15 years now. There may be enough for the room. We are considering having it put in the room. In fact, it is almost a sure thing that we will be replacing the floor with the maple.
Thanks,
Eric
Thanks Everyone for your kind replies. I have decided to use KILZ. It was a tossup between KILZ and B-I-N but KILZ finally got the nod.
Thanks Again,
Eric
   / Which paint for covering up smells #18
Thanks,
Eric
If it were me, I would find the source of the wet/damp before painting and deciding next steps. It may have a simple explanation like your tenant having a cotton rug where he let his wet boots drip dry, but it might not, and the "might not" possibilities would worry me about smells. I think pulling the floor up to look is an excellent idea.
I would put a liner under your maple to let the floor move a bit relative to the new maple as they are probably going to be in different states of water content/dryness. Just my $0.02
All the best,
Peter
   / Which paint for covering up smells #19
Ozone generator. However they really only work when the humidity is low. It may take days or running it or many cycles at it but generaly it's the most hands off approach. They also kill everything living including mold.
Bleach may sound and feel like its killing things but bleach needs oxygen to kill things. White vinegar kills what's below the surface, where a constant stink is. I would still spend $60 on a ozone generator. In today's age that's only about 2gal of paint.
   / Which paint for covering up smells #20
Do be careful if you use an ozone generator. You do not want to breathe that in, in any kind of concentration. It will give you an instant headache that will last a long time, at the minimum, and potentially worse. Just basically use your head when you go to shut it off and open the place up and make sure you don't get a face full of it. But they are very effective as long as you take reasonable precautions.
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
(APPROX. 20) 4' X...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
