Kubota L-275 Starting issue.
   / Kubota L-275 Starting issue. #1
Dr. Durango Dave
Kubota L-275
I will try to be succinct. (Not easy for me)
1-Kubota L275 1984
2Thought battery was going bad because I always had to jump it to get enough juice.
3 Tested battery. All good
4 Tractor quit giving me anything; No turning over, no glow plug, no sound at all.
5 Bypassed system by connecting hot jumper to solenoid, negative to starter ground.
6 Solenoid started jumping (as it should) VERY little turning over of engine. Very little juice.
Any help would be appreciated.
   / Kubota L-275 Starting issue. #2
1-Kubota L275 1984
I would start at the battery terminals, then the main positive to starter, than main ground at the starter.
   / Kubota L-275 Starting issue. #4
Wires might be bad inside the plastic/rubber covering?
Yes. It happens quite often but I would test before replacing cables. Use a good set of jumper cables to run temporary cables from the battery to the starter. Then see if it starts with the key.
Just make sure not to short the jumper cables and keep polarity correct. Also you want to connect the jumper cable on the starter to the same place as the one from the battery.
OK, did as you said and jumped the tractor using my 5.7 RAM. Hot to Solenoid, ground to tractor frame.
Glow plug lit up like a Christmas tree. Waited 10 seconds to start. She kicked over like a new born colt! I must have bad wiring somewhere.
Thank you much for your help!!
   / Kubota L-275 Starting issue. #7
I would have used the battery on the tractor to jump with the cables to the starter. That way you also eliminate a bad battery although I do not think it is bad. But jumping positive post to starter only then trying then ground only then trying would tell you which cable is bad.
   / Kubota L-275 Starting issue. #8
I have an L235 - same as yours with a smaller engine. I have the same problem and I've traced it to the connector at the key switch. I replaced the key switch but it still does not work, I have to jiggle the connector until I get the proper contact. I need to remove (and replace) both ends of the connector. The contacts are corroded.
   / Kubota L-275 Starting issue. #9
That was my first thought, However, the glow plugs aren't getting sufficient power either, and (I think) on the L275, it's not a key switch, it's a separate knob on the right of steering wheel, over near the hand throttle side, below the gauges
1273 (A50490)
1273 (A50490)
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
