/ Solar Generators - any members on site share experience and knowledge on what to purchase what run away from
MattB4
Gold Member
- Joined
- Aug 4, 2023
- Messages
- 385
- Tractor
- Cat 262 skid and Typhon XVII
A lot of folks get there first solar experience with the HF kits. They however are not the best buy. Typically you can get 100w RV panels on Amazon or Ebay for around $60. Be careful though since there is some scam merchants that sell misrated panels. 100w panels are generally about .45 square meters in size. This is because Panels must be rated based on STC (standard test conditions) of 1000w per square meter of full sunlight. The Panel's watt rating is directly correlated to the efficiency of the panel such as 22%. Thus 1000w at 22% = 220w for a 1 square meter size.
RV panels, or 12 Volt panels, are so named because they can charge a 12vDC battery and often used on RV's. In order for them to do this they will have a Voc spec of around 22vDC and a Vmp rating of around 18vDC. Voc (volt open cell)is the voltage the panel will read in sunshine with no loads attached. Vmp (volt max power) is the voltage the panel has when it is producing at maximum. 18vDC is sufficient to charge a 12vDC battery that might reach 15 volts during types of charging. Panels produce nothing without being loaded other than a Voc reading.
In order to take the power from panels to use charging a battery at correct voltage and amount of total charge you need a charge controller.
So if you make your own setup you'll need; Panels, SCC and battery. All of these are easily sourced. If you want AC from your DC battery you'll need an inverter. The one thing you should keep in mind is that
Watts=Volts X Amps.
A 1 amp draw from a 120vAC inverter output is 120w however the battery sees that as 10a draw since it is 12vDC. (still 120w but different voltage) Thus if your battery has a capacity of 50 amp-hours it can provide that 10a for ~5hours.
Watts=Volts X Amps.
