Solar Generators - any members on site share experience and knowledge on what to purchase what run away from
   / Solar Generators - any members on site share experience and knowledge on what to purchase what run away from #11
A lot of folks get there first solar experience with the HF kits. They however are not the best buy. Typically you can get 100w RV panels on Amazon or Ebay for around $60. Be careful though since there is some scam merchants that sell misrated panels. 100w panels are generally about .45 square meters in size. This is because Panels must be rated based on STC (standard test conditions) of 1000w per square meter of full sunlight. The Panel's watt rating is directly correlated to the efficiency of the panel such as 22%. Thus 1000w at 22% = 220w for a 1 square meter size.
RV panels, or 12 Volt panels, are so named because they can charge a 12vDC battery and often used on RV's. In order for them to do this they will have a Voc spec of around 22vDC and a Vmp rating of around 18vDC. Voc (volt open cell)is the voltage the panel will read in sunshine with no loads attached. Vmp (volt max power) is the voltage the panel has when it is producing at maximum. 18vDC is sufficient to charge a 12vDC battery that might reach 15 volts during types of charging. Panels produce nothing without being loaded other than a Voc reading.
In order to take the power from panels to use charging a battery at correct voltage and amount of total charge you need a charge controller.
So if you make your own setup you'll need; Panels, SCC and battery. All of these are easily sourced. If you want AC from your DC battery you'll need an inverter. The one thing you should keep in mind is that
Watts=Volts X Amps.
A 1 amp draw from a 120vAC inverter output is 120w however the battery sees that as 10a draw since it is 12vDC. (still 120w but different voltage) Thus if your battery has a capacity of 50 amp-hours it can provide that 10a for ~5hours.
   / Solar Generators - any members on site share experience and knowledge on what to purchase what run away from #12
I picked up a pair of EcoFlow Delta Pro units along with external batteries, for a total of 14+ KWH, 120/240 power. They are factory refurb (sold by EcoFlow) and ran about $ 7500 for everything. These will be for short term power outages. Longer outages I will start my 10KW Kubota genset. It makes like easy for myself and my wife to bring back power quickly without hassle. The equipment was all in like new condition, and shipping was free (good since everything was about 400 lbs). Using the same transfer setup with a selector for battery or genset.
   / Solar Generators - any members on site share experience and knowledge on what to purchase what run away from #13
There is a lot going on in the solar panel field AND the electrical storage (batteries) field. UNLESS you have an immediate requirement it might be better to ease into it unless money is no object.
Another factor in the U.S. is taxes. Rebates and tax savings seem to come and go.
IF you have a good "gas" generator setup perhaps the best route would be to task your son to write a proposal outlining your houshold needs and what to get.
   / Solar Generators - any members on site share experience and knowledge on what to purchase what run away from #14
Are those any good? I bought a HF solar maintainer a few years back and it was useless. Voltage output was lower than the battery voltage.
100W doesn't seem like much. Might run a radio or charge a cellphone or something, but not likely much else.
The battery maintainer from almost anyone these days are not worth it.
Yes, the HF 100W kit is a level above the solar beginner. The kit uses the automotive/RV trailer Essex connectors. Rather simple and ease of use. The kit's charge controller can handle upwards of 3x 100W panels. So, you can grow the system. I didn't just run out to get it on a whim either. Grab the coupon and look for the best prices. They run sales typically in December and a month in the 1st quarter typically.
I have the 100W kit and a Renology panel as well. This runs all of the farm needs like fence energizers, all lighting in the barns, goat water bucket warmers, charging the Ryobi 20V power tool batteries via a 150W inverter off the battery bank.
Now, MattB4 has an excellent point, it's not just the panels, it's how to do the math to charge the battery bank. And it depends on the battery technology you choose or what your wallet can afford.
Now, I tend to cheat some. I can take a charged Ryobi power tool battery and a DC-DC convertor of 24VDC to 12VDC and power things twice as long nearly. It's more incredible this way as 20VDC lithium power tool batteries are plentiful.
And you can setup a battery bank to be DUAL output power of 24VDC and 12VDC simultaneously too.
point A= 12V for legacy components
point B= 24V for modern components
point C= ground
If you fabricate your own Edison batteries, you can make these combinations too.
point C= ground
Wow, tremendous amount of experience is being shared not sure I could reciprocate on this subject For some time. I am novice until I experiment based on the shared suggestions provided . I do Thank everyone for their input of good and bad. That is half the battle investing in right hardware for Solar generator and supporting Solar array. Definitely couple of lines of thought one on build your own and other on prebuilt unit knowing best to buy. I had looked closely at Percon and Ecoflow following by Bluetti. Thinking 2000 watt inverter with at least 4800 watt surge. I Like newest battery offering that withstand over 3k cycles of recharge. Concerned this battery will not take charge unless it’s above freezing is a concern. My goal is supplement to 9000 W LPG generator. Circuits I can’t energize on gas generator I can use the Solar Generator to address other needs.
   / Solar Generators - any members on site share experience and knowledge on what to purchase what run away from #16
Westinghouse makes a very reliable 9000+W Dual fuel LPG and gas generator. Just run it on LPG and it will stay clean.
Or if you have ample storage for diesel, then get a tractor PTO genset. 10Kw, 12Kw or higher.
   / Solar Generators - any members on site share experience and knowledge on what to purchase what run away from #17
Yes bad things happen to lithium batteries if they are charged below 0F. Keep them warm.
Good luck!
Peter
2016 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2016 MACK ELITE...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
Bandit 150 Pull Behind Wood Chipper (A47384)
Bandit 150 Pull...
New Calf Hut (A50515)
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
Case-IH 370 Steiger (A50120)
Case-IH 370...
