Is this shop trying to rip me off?!
   / Is this shop trying to rip me off?! #1
jw12
Kubota L2250DT
I was asking for quotes from a local tractor shop and I was told a clutch could cost $10000! (Yes $10000) For my Kubota L2250DT. That is just the price for the clutch not labor to fix it.
I thought that was B.S.
Am I wrong?! How much does a clutch replacement cost? I was thinking $2000-$3000 was what I would pay total.
   / Is this shop trying to rip me off?! #2
Have you not took time to price the clutch online? Maybe you should.
   / Is this shop trying to rip me off?! #3
Sounds high to me. Need to know if you have a single or dual clutch. It will make a big difference in price.
Will have to add t/o and pilot bearings plus any needed seals and o'rings.
   / Is this shop trying to rip me off?! #4
I could easily see the job being $4000-$5000 if using all Kubota parts.
   / Is this shop trying to rip me off?! #5
The entire assembly with friction plates, drive plates and baskets for both clutches is just over $2k at Messicks. You should not need all of those parts unless they're really damaged. The friction plates are about $220 each. At a minimum I'd replace those and the throwout bearings.
$10k for parts is likely the "we're too busy" price. Most of the cost should be labor to split and re-assemble the tractor.
   / Is this shop trying to rip me off?! #6
Dual assy, t/o, pilot approx $2200.
Single plate, disc, t/o, pilot approx $630.
These are Messick's prices.
Labor about 10-12 hours @ $125 per hour= $1250-$1500. Not sure what current shop rates are.
   / Is this shop trying to rip me off?! #7
This sounds about right; and I think $120-130/hr is about right for shop time; about $150/hr on mobile equipment repair.
With split, your also going to have fluids, so throw a bit of money in for that. I dont think $2500 total to be out of question, but $10k? Are there significant damages to the gears?
If it's over $5k total; you really probably need to start thinking about scrapping it; it's probably worth a max of $10k in excellent shape, good tires, and a loader.
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54313)
2014 FREIGHTLINER...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
