Is this shop trying to rip me off?!
   / Is this shop trying to rip me off?! #1
jw12
Kubota L2250DT
I was asking for quotes from a local tractor shop and I was told a clutch could cost $10000! (Yes $10000) For my Kubota L2250DT. That is just the price for the clutch not labor to fix it.
I thought that was B.S.
Am I wrong?! How much does a clutch replacement cost? I was thinking $2000-$3000 was what I would pay total.
   / Is this shop trying to rip me off?! #2
Have you not took time to price the clutch online? Maybe you should.
   / Is this shop trying to rip me off?! #3
Sounds high to me. Need to know if you have a single or dual clutch. It will make a big difference in price.
Will have to add t/o and pilot bearings plus any needed seals and o'rings.
   / Is this shop trying to rip me off?! #4
I could easily see the job being $4000-$5000 if using all Kubota parts.
   / Is this shop trying to rip me off?! #5
The entire assembly with friction plates, drive plates and baskets for both clutches is just over $2k at Messicks. You should not need all of those parts unless they're really damaged. The friction plates are about $220 each. At a minimum I'd replace those and the throwout bearings.
$10k for parts is likely the "we're too busy" price. Most of the cost should be labor to split and re-assemble the tractor.
   / Is this shop trying to rip me off?! #6
Dual assy, t/o, pilot approx $2200.
Single plate, disc, t/o, pilot approx $630.
These are Messick's prices.
Labor about 10-12 hours @ $125 per hour= $1250-$1500. Not sure what current shop rates are.
   / Is this shop trying to rip me off?! #7
This sounds about right; and I think $120-130/hr is about right for shop time; about $150/hr on mobile equipment repair.
With split, your also going to have fluids, so throw a bit of money in for that. I dont think $2500 total to be out of question, but $10k? Are there significant damages to the gears?
If it's over $5k total; you really probably need to start thinking about scrapping it; it's probably worth a max of $10k in excellent shape, good tires, and a loader.
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
