M62 observations and questions
/ M62 observations and questions #1
whoodle
N. Vermont
JD 110tlb, rtv900.
I just took delivery on an M62 which is slated to replace my Jd110 tlb. Only have 30 hrs so far, but I wonder about some the operations. I had every option on the 110, and used them all in full, so I tried to mimic the setup on the m62. Backhoe huge, and yup I promptly took out the bottom panel of my garage door. Since I haven't used everthing so far, I expect to add a few questions as time goes on. The first thing that surprised me: I was pulling 30 inch diameter pine stumps that had been ageing for several years. When fresh the 110 could not budge them. The M62 did great on the aged, but could not get the fresh(they will have to wait). This question relates to a post I saw about he m59 check valves. When I grabbed a detched stump with the thumb, tucked it close to the boom so that I could lift it off the ground, I then raised the dipper to put the stump up a level. To my surprise, as I raised the dipper the boom let it sink to the ground. I do not believe the 110 would do that. It might not have lifted, but the opposing cylinder would not let loose. Can anyone tell me if I'm dreaming?
/ M62 observations and questions #2
I had a m59 for about 5 years and a m62 for about 4, so plenty of run time on both as i used them for plumbing biz, digging deep sewers..
so as you moved the dipper away from you the boom went down? That does not sound like anything i experienced but i did not have a thumb. The thumb would probably allow you to grip something more heavy than i could, i‘ve picked up some rocks that weighed decent, but still, a thumb would let you grip/balance something heavier.
What happened when you pulled the boom back up? It does sound like the relief let go on the boom circuit. I never messed with the m62 reliefs but i did snug up some of the valves on my m59. I have a pressure guage but just kinda snugged them without it. If you got one i would check it out to see what its at, very possible its set weak. They are under the plate at backhoe control, i think you just need to take the plastic cover with 2 Phillips screws to access.
/ M62 observations and questions #3
Have a M59 and have not experienced that. Difference of 2’ on backhoe might be the reason?
Agree both the loader and backhoe are scary strong. Mighty handy around the small hillside wooded farm.
Boom could not lift at all with the load. Relief valve seems a likely culprit. Id love to see the dealer take care of it. Good service is pretty rare around here.
/ M62 observations and questions #5
I agree with the above posts on my M59 - my boom won't drop to the ground pushing the dipper out.
You have a longer stick on the M62 so that's not going to help with regards to pulling power and it will put more load on the boom due to leverage.
FYI I would recommend a ripper instead of a bucket for yanking roots, I get way more power to the root with the ripper instead of moving dirt and root with a 24" bucket.
/ M62 observations and questions #7
Well congratulations!
We have one of the first M59s made back in 2007. We came real close to buying a JD110 because we like our JD310SG so much. But even the extra power of the 310 won't budge a fresh fir or pine stump in stony ground half the size of the 30" monster you describe. Not even if I dig around it - and of course there is no way at all to dig under it. A few times I admit to having leaned on a fresh stump with one BH tooth and peeled off sections. That's called "machine abuse" and a good way to make a good hoe into an old hoe real quick...
We have a hydraulic thumb - it is wonderful. No ripper yet. But wish we did.
On the boom falling ... what? .... My M59 backhoe valves don't let loose like that. Not sure any backhoe will. When I started reading, I thought that you were going to say the front end came off the ground.
Why would the boom drop? Are you sure it wasn't just the front end rising up? I think it must be...., aren't there check valves/relief valves set to prevent the boom falling? Maybe we ought to look in the workshop manual and see.... it's a good manual.
Now that I said that, the main boom cylinder on our M59 did have to be replaced under warranty. But not for that reason. The BH control valves are a joy to use.. Far better than the JD.
If you don't have a good dealer - or even if you do - it's a good excuse to make up a hydraulic T fittings with a 5000 psi fluid damped gauge. They are addictive to watch, too.
Welcome to the club.
rScotty
A ripper would be good. I have a 16 inch bucket, but in this instance i was using a 30(with thumb). Sometimes feels like a wrecking ball on a small boat🙃. Mind that the trees we cut 8-9 years ago. As I raised the stump with the dipper, the boom cylinder released and lowered the stump to the ground with a hissing sound. I did it a couple times because it seemed like an unusual occurrence. I like the p gage idea, but I don’t really want to mess with it. For a 100k it should do 0-60 as advertised!
/ M62 observations and questions #9
Troubling with a new machine. Hopefully get some dealer support to troubleshoot and repair.
Symptoms like a pressure relief.
I’m no expert, just know enough to get into trouble. Pressure relief valves on our kind of equipment protect from pump pressure, not dynamic external forces. By moving or forcing external loads a hydraulic circuit can see pressures nearly twice what the pump can do. The pressure is on the control valve and circuit components. Suspect an O-ring in that circuit control valve is leaking by. Damage from assembly, debris in system, bad valve bore or combination. My scientific wild ass guess, SWAG. Much better experts on here.
Have a 10,000psi gauge plumbed into loader lift circuit to monitor pressure. Curl circuit force, wheels pushing and transporting jolts can produce pressures twice the what the pump and relief can. Held by the control valve. Designed to handle intermittent dynamic loading. Rare to see relief valves protecting from dynamic loads on our type and scale of equipment. M62 does does have bigger backhoe so maybe?
/ M62 observations and questions #10
I've never experienced that with our M59 - or anything like it. We use our M59 as a crane far more than we use it for digging and some of the loads are high. Back in 2007/08 when the M59 first came out there was a group here who bought them and traded lots of posts for a couple of years. I think it ran to 50 pages or so. Don't recall anyone mentioning anything like what you are seeing. If what you are describing was normal behavior I think someone on TBN would have experienced it.
I have not had the need to take this M59 hydraulic system apart, so all I know about it is from looking through the shop manual. FWIW, that is an excellent manual.
What you are describing doesn't sound like it is in the cylinder. It sounds like it is in the control or relief valves. I think your best move is to insist on a complete new valve assembly. Working on the valve stack looks time consuming & complex.
If this is a new machine and under warranty I'd be very formal about having this documented. It's a safety issue.
rScotty
/ M62 observations and questions #11
Acts to me like your port relief valve on the boom lift circuit is simply set at too low of PSI, assuming it has one. With a pressure guage it’s a simple adjustment that I occasionally have to make on my excavator to match the requirements of the tool I’m running with that circuit. That being a new under warranty machine I’d definitely let the dealer check/adjust to proper spec. Possibly that being a m62 with longer stick it needs to be set slightly higher than was necessary with the m59 .
/ M62 observations and questions #12
You know, 7G, that's a real possibility. The M59 - and presumably also the M62 - do have those overload relief valves you mention. In fact, there are a pair right there on the boom control valve for the boom circuit. One each for each side of the boom cylinder circuit being protected. That would be a very simple fix.
The function of the overload relief is just as you say - to protect the control valve circuit from outside forces. And extending the dipperstick would trigger that relief since it would appear to be an outside force on the boom cylinder circuit.
There are also overload reliefs on the dipperstick, bucket, and something similar on the swing circuits. All those circuits have a pair of overload relief valves. There are other relief valves that protect the pump pressure side of the control circuit, but that isn't the problem here.
The thing is, it is rare to trigger those overload relief valves. They tend to be set higher than the pump pressure psi so you can use full power on the hoe. Checking them is a simple matter. It just takes an adapter, a tee fitting, and a pressure gauge. Any dealer will have it. The relief valves themselves are easy to swap out. Might as well check the load check valve between the ports while you are there. O rings cost two bucks...
On our BH the overload relief valve is set (by Kubota) so that the whole front end and loader bucket will come off the ground before the boom cylinder moves at all. That's typical. In fact, people break backhoes all the time by loading up the front bucket so that the boom will lift more without the tractor rearing up. I've done it myself.....
Uh, I better add an edit. I have done that - put a load of dirt in the bucket to keep it from rearing. But so far have not broken anything. That's probably due more to good luck than good practice. Definitely not something to recommend.
rScotty
/ M62 observations and questions #13
I tend to notice a hydraulic oil smell after running the BH on my M59 do you guys get that as well?
/ M62 observations and questions #14
No, not on mine. I kind of expected to smell them because sitting in the backhoe position puts us us right above that hydraulic sump vent.
But I tend to do all my work with the engine running fairly slowly - at a high idle. So nothing gets very hot. Maybe that's it. Plus I try to at least look at the hydraulic radiator to see if it is clean - it always is.
I wonder if different fluids smell different. I've never noticed that, but maybe so since they sure do sound different.
So far I've run New Holland Ambra G134, SUDT, and JD Hy-Gard. The New Holland was best for sound. I'd like to try Super UDT2, but don't yet trust Kubota fluids.
rScotty
/ M62 observations and questions #15
Haven’t noticed a smell. Use Sudt and factory filters.
Want to open the overload valves on the swing and boom valves to make check for debris and Oring condition. Hard to believe a tiny bit can cause intermittent total loss of function. Can hear flow but no force or movement.
/ M62 observations and questions #16
Do you see two different M59 valves in the parts pictures? Or different settings? Which are which? They don't seem to match the Shop Manual.
The M62 parts on Messicks parts site seems to show a a completely different set up for the valve stack and overload valves - and they are rebuildable. Maybe Kubota is working on the problem.
Thanks guys!
Happy new year to all. The dealer increased the relief valve when installing the rear hydraulics recently. I haven’t checked the function yet, but I plan to go out to the very same stump. It sounded like it was a very easy fix. I tend to run my back hoes at about 2000+ RPM and they all smell like hydraulic oil after a while.
/ M62 observations and questions #18
Hydraulics work best at rated rpm’s. Somethings like ctl’s need at least 1/2 throttle because 1 pump supplies another and can starve it. Hence the whine at low rpm’s. I almost always ran my m59/m62 at 3/4 to full throttle. Same with my mini x’s. And yeah you smell fluid when you’re good and warmed up, especially if your smeller works good. Some might not pick up on it as good as others.
/ M62 observations and questions #19
Thanks guys!
Great! From the shop manuals, the M59 and M62 have very different backhoe control valve stacks. The relief and check valve design of the M62 looks like a big improvement. They are simpler, rebuildable, and way less expensive. Let us know how the adjusted relief setting works.
I still haven't added a pressure gauge to the backhoe myself, although I have one on one loader.
Check around and you will hear different operators running their machines at different RPMs to suit themselves and what ever job they are doing. No reason not to go full throttle when digging in dirt, and no reason not to go at an idle when placing boulders buildng a berm. As for RPM affecting BH lifespan, I've never known it to make much of a difference.
Back in the day we used to decide if differential and hydraulic fluid needed changing by opening the fill plug and smelling it. It was such a common test for mechanics to do that nobody really questioned if it was right or not. If it smelled burnt it got replaced. Trouble is, most of it smells kinda burnt to me.... so I sure don't know.
rScotty
rScotty
Funny!
My bro is a crack mechanic and we alway judged tranny and gear oil by smell. Relief valve adjustment worked well. Now predictable lift. Noticed the float on the loader does hold for squat. Maybe a detent adjustment. Cold and snowy here so the m62 is hibernating and I reverted to the old 110 for snow blower and v plow.
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
PALLET OF ROLLERS (A60432)
PALLET OF ROLLERS...
2014 Ford Transit Connect XLT Passenger Van (A59230)
2014 Ford Transit...
