Detach 48x28 Garage - Footings
   / Detach 48x28 Garage - Footings
Totally DYI!!
Couple Allen wrenches/socket on impact to install opener
1/4” drill bit for electric lock
Comes with staples for photoeye wires.
PM me if you want more info. I’ll give you my phone number
I will give it a try. There are some YouTube videos showing the install. Doesn't look too bad.
Jackshaft openers look easier to install than the ceiling hanging chain/belt drive ones.
Is Amazon a good place to buy the opener?
Also looks like Raynor and Liftmaster are the same brands. Raynor rebrands LiftMaster openers under their own name.
   / Detach 48x28 Garage - Footings #142
They are fairly easy.
Amazon isn’t a bad place. You can option them out like car.
Stick with the Liftmaster for parts availability/tech support.
   / Detach 48x28 Garage - Footings #143
Yup, they are easy. Second one will obviously go easier than the first once you understand what goes where and how to set/program.
But Id say absolute worst case for an armature is both in a day easy. So is a days worth of your time worth the $1000 saved
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
safety baskets (A53421)
safety baskets...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
