I'm thinking about upgrading to a Ford 3000 or 4000 series
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
Just thinking... I would have to sell my Kubota to pay for it. It would be over a half century old yet it seems like there are clean units out there.
Concerns:
Would it be able to handle a 3pth BH without tearing the rear housing off?
I would be going from a 3000 lb 4WD to a 4000 lb 2WD.
I've always liked those old Fords. My father had a 4400 gasser... when he passed away I would have brought it home but it had been sitting for a couple of years and I couldn't get it going. We sold it 3 years ago for a paltry $3000... after dragging it out of the barn so that I could get it going.
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #2
maybe describe your uses & reasoning for the upgrade. i'd be checking out other options as well, lots out there on 2nd hand market, best regards & don't forget to check sub frame units as well
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #3
The 3000 is a good light to medium weight implement puller, easy to get on and off and plenty of operator space with usually a vertically spring tensioned back seat giving about 4" of deflection....way better than the 1-2" of horizontal spring suspension seats, and these seats are readily available and due to their popularity, a few years ago could be had for $100...no idea as today's prices as I don't need one.
The 8 speed is the preferred transmission, 4 gears and 2 ranges. My 8 speeds have no problem pulling a 6' rotary tiller mounted on the 3 pt. slow enough.e Live PTO is common. Live PTO is a double clutch system whereby the clutch pedal, when fully depressed disengages both clutch discs. When you allow the clutch pedal to rise to mid position, the PTO clutch engages and as you allow the pedal to rise above that the ground driving clutch engages. For putting in post holes in a fence row, this is an ideal setup for digging post holes......even better than an "independent" (engage is manual, regardless of what else is going on as long as the engine is running). However, independent is preferred for a lot of tasks but live holds it's own in these circumstances too.
Some were equipped with front end loaders but I think that the 100 and 1000 series smaller tractors didn't have an adequate front end to support much if any loader work. One of my 4000s had the front axle welded where it had broken under FEL loads and when purchased it had the front end, crankshaft driven hydraulic pump with the tubes (frame) of the loader carrying the fluid inside those tubes rather than using the tractor sump like the 3 pt uses.
I have a '65 diesel and also had a '66 diesel.....used as a trade in for another, larger tractor.....currently have 6 working tractors, 25-65 HP.. These are about as fuel efficient a machine that is available and are bulletproof. The later 3000 series have upgrades that are worth your attention. I also have a 1980 3600 and a 1990 3910.
Power steering is really nice to have and if you find one without it, kits are available (ebay for one) whereby you can add aftermarket power steering. I have one of those on my 3000. The other two came standard with PS.
Usually they are reasonably priced and have few things to fix that are easily accessible, inexpensive, and readily available. New dash assemblies are cheap and popular and a coat of paint and a new dash panel makes you think you are sitting on a new tractor.
I had a couple of older 4 cylinder 4000s and they were slightly larger and heavier than the 3000 with the same things I posted above. The 3000 came out in '65 and was a midsized tractor between the 2000 (older 600 series) and 4000 (older 800 series). The older tractors were 4 cylinder up until the first 3000 was available in '65 and all the 1000 series mentioned dropped down to a 3 cylinder design after that.
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #4
You'll regret selling the Kubota; if you can, bite down on the bullet and make the painful shifts needed to own both. Take more time if need be.
You'll have the Ford for when needed, or just wanted, and the Kubota for convenience sake. You'll never regret making it work.
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #5
No value to add about the question of adding a backhoe to an old Ford, but I've put many of hours on my fathers 68 Ford 4000. That's a great tractor, heavy with loaded tires to. Can't go wrong with an old Ford but I don't think I would trade my compact CX2510 for one.
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #6
It's hard to be modern creature comforts and convenience features.
   / I'm thinking about upgrading to a Ford 3000 or 4000 series #7
Main reason is his 4000 is 2WD and no loader.
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55314)
2023 Kubota...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A55314)
2020 John Deere...
KMC 5610 (A53084)
KMC 5610 (A53084)
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
