How to fix a hazed-up wood burning stove pyro-ceramic glass
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
I;ve done some research on this, but thought I would give it a shake w you guys to see if you have the solution.
Have a 2002 22" Dutch Vermont wood burning stove...it's awesome. For the last 10 yrs, I get this haze on the bottom, that has now further up and to the center. I have used cleanser and water w paper towels, but that only gets what was recently put on the glass. The hazy part just seems to get bigger over time.
Is there a real solution, or buy a new glass?
Or, is there a cleaner w a fair amt of elbow grease that works?
Or, do I get a oscillating polisher w very fine polish?
I would appreciate your help on which way to go...I have a polisher and various attachments w polishing pads. Questions?
thank you very much
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #2
I use white vinegar and a paper towel.
Recent thread, worth the read!
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #3
Best stuff ever !!
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #4
I have a bit of haze on my wood stove glass as well, I think it might be from the heat, not sure though. I find the best way to clean the glass is with a slightly wet paper towel and dip it into the fine part of the ashes and then wipe that on the glass and scrub a little. Then wipe it clean with just water on a fresh paper towel. It's cheap, easy to use and does a pretty good job. Then just throw the used towel into the wood stove once it gets burning nicely.
Hope this helps!!
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #5
Hope this helps!!
Yes! Exactly what I do! Works great! I usually go after the haze about once a week. Doesn't build up as much and can just be 'wiped' easily.
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #6
i use some easy off degreaser/ oven cleaner. works great.
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #7
Hope this helps!!
Exact thing we do. Works great
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #8
There are two kinds of haze I have found.
The first occurs quickly , like in days and can be easily removed in the ways already mentioned.
The second occurs over the years slowly as the stove ages with time and many fires. I believe it is IN the glass not ON it. Don't think there is anything can be done in this case.
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #9
New glass may be needed if its too far gone.
When the glass is cold I use a paper towel and water. Seems to work just as well.
   / How to fix a hazed-up wood burning stove pyro-ceramic glass #10
Yeah, it's almost like the inside of the glass is etched. Doesn't really bother me. I'll clean it once a year in either the spring or fall. Stove is in use continuously once it gets cold.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
2018 MGB 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MGB 2500HP...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
