Kubota L3200 snow removal
   / Kubota L3200 snow removal #1
Fish92
John Deere 1530
I would like to hear some success stories with a front mounted QA snow blade on a Kubota L3200 (or similar tractor). I currently use an 84" three-point blade but it does not handle the deep snow well unless I spin the blade 180 degrees and drive backwards. I have a long gravel driveway that is almost 1/4 mile from the road to the barn.
What have you found that works?
   / Kubota L3200 snow removal #2
Just be careful when pushing with rear blade no trip spring.
7'+ front blade will cut your plowing time in half,and you can push snow back further.
Thanks Thomas. Any recommendations on a certain blade? I'm a little concerned with how the hydraulics will handle a front blade as most seem to sit far away from the QA, even if the angle is manual.
Kevin
   / Kubota L3200 snow removal #4
I have plowed with a 7’ back blade and Kubota L3130 since 2005. No snow was too much really. I am old now and got a cab tractor and blower for the extreme cold we get -20°F or more. But I used the Kubota today for yesterday’s 8” and it did great, warm here today at about 20°. I did use the Case blower earlier this week for the 40” we got, but it was -26°.
So never had any issues with my L3130.
   / Kubota L3200 snow removal #5
If a problem that you’re having is that the blade floats up with deep snow, and doesn’t scrape down far enough even with multiple passes, there are two things to try.
1 - angle the blade down a bit more by shortening the top link
2 - add weight somehow to the blade (like strapping cinder blocks or those 80 lb sand bags on top of the blade).
   / Kubota L3200 snow removal #6
Kevin
My setup different than what your thinking of,I didn't have any problems.
Are your rear tires loaded or rear ballast?
   / Kubota L3200 snow removal #7
Why do you need a trip spring on a rear blade? I’ve been doing that for years with the 3ph in float.
   / Kubota L3200 snow removal #8
When pushing backwards hit solid object etc. trip springs will release pressure,no trip springs shock from hitting object 3 pt. hitch transmission will take hard hit,solid hit that stop tractor could cost $$$'s in repairs.
   / Kubota L3200 snow removal #9
I had an L3200 and used a rear blade and loader for a while. Then for a couple years ran a Pronovost 64" rear blower. Best thing so far is the QA mounted blade on the L4240. It's a lot faster than anything else and being mounted on the FEL means snow can be piled up easily. Whatever you do, make it so the blade is suspended on a chain so it can be floated with only the weight of the blade. Do a search for "underslung snow plow". A few of us built them and this method helps prevent the plow from becoming a rudder.
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
