Hydraulic motor on rear blade
   / Hydraulic motor on rear blade #1
TractorBluez
Wisconsin
Ford 8N Ford 861 Ford 4000 Ford 5000
Has anyone tried setting up a rear blade with a hydraulic motor for 360-degree rotation? Or does this fall into the "dumb idea" category.
   / Hydraulic motor on rear blade #2
Might work but you need a way to lock the blade..
   / Hydraulic motor on rear blade #3
Think of the forces if you snag a corner!
   / Hydraulic motor on rear blade #4
would potentially work with motor that is large enough to with stand torque demands or like Peter states some mechanical lock or brake to hold position.
   / Hydraulic motor on rear blade #5
That’s exactly how the blade on an actual road grader rotates. The downside is the cost to build something like that would be substantial.
   / Hydraulic motor on rear blade #6
It’s possible
   / Hydraulic motor on rear blade #7
You would have to build it like a turn table on a track hoe. Which is probably like a motor grader is made.
Thank you for your comments everyone. I had a feeling the forces on the hydraulic motor could be an issue. D & D, I hope your project turns out well after all the thought you've put into it. Like you, I'm tired of getting on/off the tractor to adjust the blade. Would be really nice to adjust it in each direction and angle from the tractor seat when snowplowing driveways.
   / Hydraulic motor on rear blade #9
How often do you need 360° rotation? Are you switching between pushing and pulling a lot?
90° rotation (+45°, -45°) would be easy enough with hydraulic cylinders. Then a pin would allow you to reverse it, but that would require leaving the seat.
There are probably a few ways to achieve the 360° rotation. Perhaps a large rotating table plus a large ring and pinion gear.
I'm not sure what would be able to donate a ring and pinion. A typical starter motor ring and pinion likely wouldn't be sturdy enough. Are there drive gears for a small dozer?
Perhaps head to a tractor recycler and see what strikes your fancy. Good heavy duty hub + the ring and pinion.
I like the idea of looking for a scrap small grader, or scrap mini excavator.
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
Case IH 250 Magnum (A57148)
Case IH 250 Magnum...
TOTE OF RIMS (A58214)
2007 ATLAS COPCO XAS185 JD7 AIR COMPRESSOR (A52709)
2007 ATLAS COPCO...
JOHN DEERE 9570 RX (A58216)
JOHN DEERE 9570 RX...
11' CONTAINER (A52706)
