Hydraulic motor on rear blade
   / Hydraulic motor on rear blade #21
Another option would be to use a hydraulic rotary actuator. They are made to have much more torque than motors and provide a controllable rotation. Most do not have 360 degree rotation. To get the torque you need you would most likely need a double rack unit.
A planetary final drive would probably work also. Any equipment salvage yards around you?
   / Hydraulic motor on rear blade #22
Interesting ideas, I use my blade going forward and backing up quite often. I do have hydraulic angle and tilt with an option for hydraulic offsett.
When I rotate my blade 180 I have to unpin my angle cylinder spin the blade the 180 and repin the angle cylinder.
   / Hydraulic motor on rear blade #23
Torque definitaly an issue with just a direct drive motor setup.
It CAN be made to work with many of the ideas mentioned here.....but whats the budget for this project?
1988 Mack R690ST Day Cab Truck, VIN # 1M2N277Y9JW007124 (A57453)
1988 Mack R690ST...
Hydraulic rail grinder (A56436)
Hydraulic rail...
Mini Excavator Hydraulic Thumb (A55272)
Mini Excavator...
2008 Ford Explorer SUV (A56859)
2008 Ford Explorer...
2017 Ford F-150 XLT (A57148)
2017 Ford F-150...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
