Hydraulic motor on rear blade
   / Hydraulic motor on rear blade #1
TractorBluez
Wisconsin
Ford 8N Ford 861 Ford 4000 Ford 5000
Has anyone tried setting up a rear blade with a hydraulic motor for 360-degree rotation? Or does this fall into the "dumb idea" category.
   / Hydraulic motor on rear blade #2
Might work but you need a way to lock the blade..
   / Hydraulic motor on rear blade #3
Think of the forces if you snag a corner!
   / Hydraulic motor on rear blade #4
would potentially work with motor that is large enough to with stand torque demands or like Peter states some mechanical lock or brake to hold position.
   / Hydraulic motor on rear blade #5
That’s exactly how the blade on an actual road grader rotates. The downside is the cost to build something like that would be substantial.
   / Hydraulic motor on rear blade #6
It’s possible
   / Hydraulic motor on rear blade #7
You would have to build it like a turn table on a track hoe. Which is probably like a motor grader is made.
Thank you for your comments everyone. I had a feeling the forces on the hydraulic motor could be an issue. D & D, I hope your project turns out well after all the thought you've put into it. Like you, I'm tired of getting on/off the tractor to adjust the blade. Would be really nice to adjust it in each direction and angle from the tractor seat when snowplowing driveways.
   / Hydraulic motor on rear blade #9
How often do you need 360° rotation? Are you switching between pushing and pulling a lot?
90° rotation (+45°, -45°) would be easy enough with hydraulic cylinders. Then a pin would allow you to reverse it, but that would require leaving the seat.
There are probably a few ways to achieve the 360° rotation. Perhaps a large rotating table plus a large ring and pinion gear.
I'm not sure what would be able to donate a ring and pinion. A typical starter motor ring and pinion likely wouldn't be sturdy enough. Are there drive gears for a small dozer?
Perhaps head to a tractor recycler and see what strikes your fancy. Good heavy duty hub + the ring and pinion.
I like the idea of looking for a scrap small grader, or scrap mini excavator.
TAKEUCHI TB235-2 EXCAVATOR (A52709)
TAKEUCHI TB235-2...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A57453)
2016 Hino 195h...
