Why does my IH 504 tractor won't restart until cool
   / Why does my IH 504 tractor won't restart until cool #1
nduetime
I was cutting pastures for 1+ hours when the tractor stopped running with a puff of white smoke coming out the side of the engine. I tried to restart but starter did'nt turn over yet dash lights were on as normal. I let it cool down for an hour then checked the oil, antifreeze level, radiator blockage and battery, all were normal and it started right up. Started cutting again for 10 minutes same thing happened. I looked at electrical connections at starter, distributor and battery, no loose / corroded ones found. Any suggestion where to look next?
   / Why does my IH 504 tractor won't restart until cool #2
Did you check the fuel filter?
   / Why does my IH 504 tractor won't restart until cool #3
Coils can do that. Check for spark next time.
   / Why does my IH 504 tractor won't restart until cool #4
Like SPYDERLK said check for spark, maybe pat/slap the coil to see if it is extremely hot, and why you want to pat or slap it, not just lay your hand on it. If you have spark, could quite possibly be vapor locking if you're pushing it pretty hard. Temperature gauge working..??
If you have spark, and it is vapor locking it's a pretty easy fix if you were around to hang with Ford guy's from the 60' & early 70's. Check your laundry room for some spring type clothes pins and clamp 2 or 3 on the fuel line. The old girl will probably run all day. The clothes pins act as a heat sink and will prevent it from vapor locking.
I have to do this on my little Farmall A if I'm using the rotary cutter on a hot day.
Are those wooden or metal clips? Can't tell from your picture.
Will do thanks
When tractor was hot the starter didn't turn over at all, yet the dash OIL and ALT lights lite up when I turned the key. Wondering what the REGULATOR CUT-OUT RELAY controls?
   / Why does my IH 504 tractor won't restart until cool #9
Wood. If you don't have any, Wally-World or Dollar General/Dollar stores have them for cheap.
   / Why does my IH 504 tractor won't restart until cool #10
Could be a bad ground too. Check your cables on both ends, especially the chassis end. You have enough current to light the lights, just not enough to ground out the starter.
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Deere 9965 Cotton Picker (A52128)
Deere 9965 Cotton...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
