Why does my IH 504 tractor won't restart until cool
   / Why does my IH 504 tractor won't restart until cool #1
nduetime
I was cutting pastures for 1+ hours when the tractor stopped running with a puff of white smoke coming out the side of the engine. I tried to restart but starter did'nt turn over yet dash lights were on as normal. I let it cool down for an hour then checked the oil, antifreeze level, radiator blockage and battery, all were normal and it started right up. Started cutting again for 10 minutes same thing happened. I looked at electrical connections at starter, distributor and battery, no loose / corroded ones found. Any suggestion where to look next?
   / Why does my IH 504 tractor won't restart until cool #2
Did you check the fuel filter?
   / Why does my IH 504 tractor won't restart until cool #3
Coils can do that. Check for spark next time.
   / Why does my IH 504 tractor won't restart until cool #4
Like SPYDERLK said check for spark, maybe pat/slap the coil to see if it is extremely hot, and why you want to pat or slap it, not just lay your hand on it. If you have spark, could quite possibly be vapor locking if you're pushing it pretty hard. Temperature gauge working..??
If you have spark, and it is vapor locking it's a pretty easy fix if you were around to hang with Ford guy's from the 60' & early 70's. Check your laundry room for some spring type clothes pins and clamp 2 or 3 on the fuel line. The old girl will probably run all day. The clothes pins act as a heat sink and will prevent it from vapor locking.
I have to do this on my little Farmall A if I'm using the rotary cutter on a hot day.
Are those wooden or metal clips? Can't tell from your picture.
Will do thanks
When tractor was hot the starter didn't turn over at all, yet the dash OIL and ALT lights lite up when I turned the key. Wondering what the REGULATOR CUT-OUT RELAY controls?
   / Why does my IH 504 tractor won't restart until cool #9
Wood. If you don't have any, Wally-World or Dollar General/Dollar stores have them for cheap.
   / Why does my IH 504 tractor won't restart until cool #10
Could be a bad ground too. Check your cables on both ends, especially the chassis end. You have enough current to light the lights, just not enough to ground out the starter.
Thanks. I checked the grounds that I could find, look good. Ran it today for 1 + hours cutting grass with no problems. It was about 10 degrees cooler today. I did replace spark plugs, cleaned the radiator, distributor cap & rotor yesterday during the rain storm. Have crankcase oil breather on order since this 2015 one looks pretty dirty inside
   / Why does my IH 504 tractor won't restart until cool #12
These 504's do get hot fast! Rad. is about half the size needed for this motor and I found vapor lock the biggest problem. BUT your puff of white smoke would be the bigger concern! Check the compression cause it sounds like an engine rebuild is getting close!
ALSO make sure rad. fins are squeeky clean ALL of the time. You might also add an electric fan to help move air. Take all of the side tins off the hood too as they block hot air from getting out.
Mine are 504-utility models but the 2444 industrial does the same thing mowing waterways.
Something I was going to do was to take the thermostat out of mine and try that. They go to 180 fast and stay there for a long time then go on to 200 slowly and after about 195 I turn into the wind and shut down for a while and go do something else.
It stopped running again after idling for a minute or so while closing gate after running 2+ hours cutting pasture grass. No white smoke, normal battery, normal temp showing, no loose connections found this morning. Let it cool down for an hour then started right back up. I'm thinking the coil is getting hot and acting up. Mine is a 1964 utility
FYI update: replaced points and condenser. Ran good today but had cooler weather too. If it happens again I'll replace the 25+ year old coil.
   / Why does my IH 504 tractor won't restart until cool #15
Sounds like in your case the coil just might be going out! Hey,--when it dies or you run a long time does the coil get hot? I mean HOT? usually they do that when they get bad.
Also check the timing! It needs to be spot on. Not too fast or slow as that adds to the problem. Tune it by ear and when the motor sounds like its running free, tighten the dist and try that.
Thanks, I'll check both.
2008 GMC Savana 2500 Cargo Van (A59230)
2008 GMC Savana...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
SAMSUNG STEAM VRT WASHER & SAMSUNG MOISTURE SENSOR (A60432)
SAMSUNG STEAM VRT...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
