Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor #491
Those spreaders and the tag along applicators with the John Blue pumps on them are deftly accurate. You can measure land with them when you have the correct overlaps. Of course they aren't as good as the new fangled Hi-Boys and spreader trucks they use now with all the GPS technology but they are still good enough for me.
The John Blue pump on the Sprayers/Nitrogen Applicators was a game changer in the fact that you no longer have to calculate and run numbers to get accurate application rates , once set the pump compensates for your ground speed and IMO is very accurate.
   / Pictures from a skid steer mowing contractor #493
Yea, if you had corn planted on 36 or 38 inch rows that applicator would run in the rows perfectly and spray overlap was perfect. It was dead on the rate number.
Today's work customer asked me to get her overgrown property/fence lines under control so she can handle it with her tractor and bush hog, it's ready for her, found plenty of old concrete blocks steel pipe and plenty of old fence wire in this mess, but she was thrilled so I'm happy.
   / Pictures from a skid steer mowing contractor #495
That's quite the before and after photo!
I have a lawn mowing customer that pays for zero turn mower only, no trimming. He lets the fence lines go (and everything else) and asks me to trim it all back every 2 years or so, which I don't appreciate. I need to charge him more.
This customer said that they hired a bulldozer to push the property lines when they bought the place so that the fence could be put up, but that was over 20 years ago so it was pretty thick with 12' to 14' high scrub oaks and vines, and yes I agree anything that a customer allows to go un-touched for years that is going to be hard on your equipment you should charge more for, fixing and making equipment repairs is inevitable and isn't usually cheap.
   / Pictures from a skid steer mowing contractor #497
Very nice work. 🏆
What happens with the trash metal and your equipment? You can't see it until after it's hit. Do you charge more in advance? How bad does your stuff get abused?
Very nice work. 🏆
This forestry mower is tough, it takes a beating and is none the worse for it, it's a 3 blade model with carbide grinding teeth on the bottom of the blade carrier, the blades are heavy and made out of AR-400 steel, I am still on the original set believe it or not, I have a new set I just haven't put them on yet. It does make me cringe when I hit hidden steel , and a concrete block will be obliterated when you hit them, my most time consuming chore is cutting fence wire out from around the bearing housing if it gets past the wire prevention studs that are welded around the housing. I will charge more if when looking at the job I see it's a junk hole, I have found abandoned cars lawn mowers etc in weeds, vines and trees that you couldn't walk through.
Today I jumped on a hardwood scrub oak thicket that the customer wanted thinned so he can sit on the back porch of the house he is building and look at the deer feed and pass thru, the scrub oaks were tough but not tough enough, we got em.
   / Pictures from a skid steer mowing contractor #500
Another great job. How thick of a sapling, both hardwood and softwood will that take down or do you try to steer clear of those?
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
160 Gallons of Industrial Cleaner (A51573)
160 Gallons of...
UNUSED HURRICANE 7' X 12' CONTAINER (A51248)
UNUSED HURRICANE...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
