2024 garden season
   / 2024 garden season #171
My father used to plant it as a cover crop in the orchards.
You could hear the whole place buzzing with bees when it bloomed.
It would self seed for the next year, so one planting would be good for 2-3 summers.
I've tried to get some to plant a block for the bees and I can't find any around here.
When I bought this place 20 years ago, the semi-overgrown fields were full of milkweed. Talk about a bee magnet! When it's in bloom you can hear the buzzing and smell the fragrance 100' away. I've left a 100 x 100 or so patch for them each year.
I wouldn't want to eat it every day but love a good portion of liver, beef or chicken, but they have to be fixed right (browned and swimming in gravy). A good stack of Buckwheat cakes.
I've always liked buckwheat pancakes, not easy to find though. When we were kids my mother used to occasionally serve chicken livers. Not awful, but I don't think I've had them since I left home 55 years ago. Beef liver? Nope, might as well eat a shoe.
zucs are dieing, corn is tasseling at 4 feet, onions are done, potatoes dont have anything under them. Gonna be a lean year here. Food bank wont get anything from us this year from the looks of it.
Do have some nice cabbage!
Good thing we had the big crops last year cause we will use that for the coming year.
Not every year is a good one.
   / 2024 garden season #173
Found a couple baby Pumpkins this morning while spraying..!!
took some cabbage and onions to the mission.
Gave some to some of my Facebook friends and made 2 jars of kraut out of 2 heads.
   / 2024 garden season #175
Second round from my mini garden.
   / 2024 garden season #176
How do you handle weed and grass control in the corn?
cultivator on tractor like they did 75 years ago.
   / 2024 garden season #179
This is pretty much what we've used here since 1954. David Bradley sold by Sears years ago. Still a lot of them out there for sale but have to be in the right spot at the right time. Many think they are worth their weight in gold. I've never paid over $100 and all have had an attachment or two. A non-runner can be repowered with a small 3 hp. Briggs engines. I've boughten more than several gas powered sidewalk edgers with Briggs engines for a replacement engine. HF engines bolt right up too. Mark rows out, then plant in those small furrows. Mark 2 rows on the first pass, then one shovel/sweep in a row for spacing. When all rows are marked, I'll trickle some stater fertilizer in the row, then run through them to stir it as little. A little extra work, but worth the effort. When it comes time to cultivate, you're dead nut on for spacing. Cleans up real nice. Still have to hoe in between plants. I plant row crops in 30" spaced rows. You could go with a 3 pt. cultivator but have to set up planting to match wheel spacing on the tractor. Most have to go 48" minimum on like a CUT, and that's lots of wasted space.
I have a set of hillers on one set of cultivators I use, usually the last pass of cultivating. Corn & beans are tall enough the shade out most weeds.
I do set my tomato plant row spacing at 6', and for that I have a couple cultivators for the Wheel Horses. One set has the OEM slot hitch, the other the sleeve hitch system. These too can be used for 36" rows. If your ground is perfectly flat the slot hitch will work well but you have to keep it straight. A slight turn of the steering wheel and you've rooted out some plants. Allowing the sleeve hitch to pivot some will give you a little wiggle room allowing it to pivot swing and pull cultivator in the direction being pulled when correcting.
Ther's a fellow out in Washinton State that does market gardening and works 5 acre fields with a smaller unit called a Planet Junior. Prices on those are out of sight. More for in between row cultivating, or short crops such as lettuce, etc. I like the Bradley's because of the 15" and 16" wheels/tires for ground clearance. Last pic is from last year cultivating tomatoes for the last time. Did between rows with Wheel Horses. Last pass before mulching with leaves and caging.
Tiller between the rows also works. I mostly use a TB HORSE between the rows. I plant everything in 72" rows here, --- plants gotta have room to grow!
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
UNUSED LANDHERO IH-IW21 1" AIR IMPACT WRENCH (A51248)
UNUSED LANDHERO...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2022 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
JOHN DEERE TX LOT IDENTIFIER 139 (A53084)
JOHN DEERE TX LOT...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
