Landpride flail Fm2584/ Victory extra wide
   / Landpride flail Fm2584/ Victory extra wide #21
Hello Shaun,
Please consider the towed Hiniker 5710 flail shredder also.
It has a 6 foot cut and a constant velocity universal joint to
allow tight turns while mowing and an overrunning clutch.
  • Hiniker5710ownersmanual79202099 (2).pdf
  • Hiniker5710partsmanual79201643RevC.pdf
  • Hiniker5710shredderlit.pdf
Hello Shaun,
That looks really well built, but I was wanting something in the 7 to 9 foot range. To bad they don’t make a wider model.
   / Landpride flail Fm2584/ Victory extra wide #23
The next larger size Hiniker shredder is 15 feet wide.
   / Landpride flail Fm2584/ Victory extra wide #24
More shredders:
Brillion 12'
Kuhn 90"
Perfect 83"
Seppi 79"-108"
Rhino 15'
Dragone 78"
Rinieri TRD 79"
More shredders:
Brillion 12'
Kuhn 90"
Perfect 83"
Seppi 79"-108"
Rhino 15'
Dragone 78"
Rinieri TRD 79"
Thanks for all the shredders to look at, I really appreciate it.
   / Landpride flail Fm2584/ Victory extra wide #26
I'll toss this one out there.
I have the 78" Betstco HD (Farmer Helper) flail mower with hammers. It's a heavy piece of equipment and has done a great job mowing pastures this summer. Any small branches that fall around the edges, it chops them up. For the price, it's been fantastic. Fairly easy to adjust. Sits slightly offset. Im pretty meticulous about the maintenance. I retighten the belts and grease it before every mowing session (5 hours). They are worth checking out if you don't mind a cheaper Chinese mower.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
BLACK DIAMOND AIR COMPRESSOR (A53843)
BLACK DIAMOND AIR...
aerator (A52377)
aerator (A52377)
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
