New Holland TC45D won't crank
   / New Holland TC45D won't crank #1
wetzelc89
New Holland TC45D
I have an older tractor. Replaced the battery, now won't crank. Fuses are all good, panel lights up, at a loss.
   / New Holland TC45D won't crank #2
Clean the grounds and the power lead to the starter. Loosen then retighten the starter bolts. I theorize there's a ton of corrosion everywhere.
   / New Holland TC45D won't crank #3
@wetzelc89 - First question is why did you replace the battery? What were the conditions that lead up to replacing the battery?
Replacing a battery is not going to cause an issue... so either their was a prior condition / issue or their is an issue with the install of the new battery... so I'm thinking... why was the battery replaced...
   / New Holland TC45D won't crank #4
The TC series had a problem with internal corrosion on the battery cable ends. It allows voltage to pass but not amps under load. Bypass them with a set of jumper cables and see if that helps.
   / New Holland TC45D won't crank #5
TC35, TC40, and TC45 have known problems with their battery cables. I suggest you do a search here at TBN, and or replace both cables. When they were crimped at the factory, over the years corrosion causes the ends and cables to put high impedance onto the current flow to and from the starter.
Happened to my neighbors TC35, took him a while to figure it out. He built two new cables and soldered the ends, not crimp them.
Kids (goats) got loose, playing on the tractor and managed to turn on the lights. By morning the battery was dead. Jumped it, worked fine. Used the tractor that day, next morning dead again. Replaced the battery. Now nothing.
Thanks, I'll check that out.
Thanks, I'll have that checked. I didn't think there was a problem with the starter, but certainly worth a look.
Thanks, worth a look.
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
NEW Fork Extensions (A53002)
NEW Fork...
Husqvarna PG280 Floor Grinder (A50325)
Husqvarna PG280...
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
